Problem with radiation heat transfer
Old   September 20, 2013, 14:10
Default Problem with radiation heat transfer
Tiago Morgado
TMorgado is on a distinguished road
Hi, I'm simulating a heating process of a slab within a furnace. I imposed the fixed values of temperature for the furnace gas and its walls . I also imposed velocity zero to the fluid.
The model just calculates the radiation heat transfer between the slab and the furnace, and resolves the equation of conduction of heat within the slab.
What I see in the results its something that is impossible!!!
Fluent is telling me that the total surface heat flux is higher than the radiation heat flux on the slab surfaces.
How could that be, if there is no convection, just radiation.
Anyone could provide some theory that would explain these results?
Thank you
TMorgado is offline   Reply With Quote
heat flux, radiation
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Comparison of radiation and convection heat transfer panos_metal FLUENT 0 December 5, 2011 21:04
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Heat transfer, convection, radiation, conduction Sandra H. OpenFOAM 1 March 3, 2010 08:02
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
