color thing
Like Tree1Likes
  • 1 Post By MARIANA LOQUITA
Old   September 27, 2013, 08:23
Default color thing
mariana
MARIANA LOQUITA is on a distinguished road
as everybody i need help.
if somebody know and want to help please answer.
my problem is that i made in CFD Fluent colculations, i have results and on the graphics i want to change color and i don't know the way to do it.
i have 2 different things and i want them to be different but i cannot find the correct tools for it.
thank you for your time and helping.
MARIANA LOQUITA is offline   Reply With Quote
Old   September 27, 2013, 11:04
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi Mariana,
can you explain more what is your problem?
Where do you want to change colors?2d plot? contours? vectors? pathlines?
Post some pictures if you can.
Daniele
ghost82 is offline   Reply With Quote
Old   September 28, 2013, 05:21
Default hey
mariana
so as you can see in the image, there is one hull( vessel) and water. i want to change the color. so it is not the same .....
File Type: jpg 1376225_10201490637219362_1417196340_n.jpg (43.7 KB, 10 views)
File Type: jpg 1371211_10201490637179361_971473299_n.jpg (44.7 KB, 8 views)
Old   September 28, 2013, 05:44
ghost82's Avatar
Rick
Hi Mariana, I understand; so you want only to have a picture of water and hull, without contours?Something like water in blue color and hull in brown?
If so, you can do this by (instructions for ansys 14.x.x):
1- Display->mesh: select surfaces of hull and water
For capture the water/air interface if you are using vof you can create iso-surface with water fraction=0,5.
select only faces and display.
2- Display->scene: select on the left the water iso-surface and click "display"; select only visible, lighting, faces, outer faces, choose face color on the right from the drop down menu; adjust the color: if you want blue just move the cursor to 255 for blue and green and red to 0; then close the window.
Select walls of hull on the left, deselect the water iso surface; click display and do what you have done before, but change color.
3- Save the picture: file->save picture
Daniele
Old   September 28, 2013, 06:21
Default hello again
mariana
no, i need with contours.....
thank you again
Old   September 28, 2013, 07:02
ghost82's Avatar
Rick
thank you again
Which contours do you want to plot?
In the attached pictures you have plotted contours of z coordinate; since there's not much difference in height, colors are very similar.
If you want to plot contours and colors are very similar you can try to change colormap colors (Display->colormap), but since values are very similar there will be not much difference in colors...
Daniele
Old   September 28, 2013, 07:04
ghost82's Avatar
Rick
Or when you plot contours deselect "auto range" then input min (a bit under water surface) and max (a bit above hull) values for z coordinate (if you want to plot z coordinate).
This will spread colormap color in a smaller z range.
Daniele
Old   September 28, 2013, 07:12
mariana
Thanks, will try now
Old   September 30, 2013, 08:10
Default Hey Daniele
mariana
thank you very much for your helping. we tried and i send you the final result.
thank you again.
File Type: jpg 1368689_10201504756332331_1656044646_n.jpg (54.9 KB, 7 views)
ghost82 likes this.
