-   -   Catalytic reaction, ratio of active to geometrical catalytic surface (http://www.cfd-online.com/Forums/fluent/124199-catalytic-reaction-ratio-active-geometrical-catalytic-surface.html)
mahmohammad September 29, 2013 15:47
Dear all,
I'm trying to simulate H2/O2 catalytic reaction on Pt. I'm using Fluent coupled with Chemkin to do that. I can do it just fine and I get reasonable results. But when I want to compare it against the experiments, I need to take the experimentally measured active catalyst sites into account. It's done by multiplying an F factor to the calculated rate of reaction at the boundaries with a catalyst. Since I don't have access to the boundary equations and species equations, what is the best way to add the experiment/geometry ratio factor?
I was thinking of multiplying the rate constant by the factor to increase/reduce the rate of the reactions.
Thanks a lot
A CFD free user September 29, 2013 16:01
Originally Posted by mahmohammad (Post 454157)
Dear all,
Thanks a lot
Hi dude
If you mean to set the value for specific active area in surface reaction which has a unit (1/m), then you can access it from Cell zone condition/ (interest zone)/ reaction/ surface to volume ratio (1/m)
Hope it helps
