Catalytic reaction, ratio of active to geometrical catalytic surface
Old   September 29, 2013, 15:47
Default Catalytic reaction, ratio of active to geometrical catalytic surface
Mohammad Ghazvini
mahmohammad is on a distinguished road
Dear all,
I'm trying to simulate H2/O2 catalytic reaction on Pt. I'm using Fluent coupled with Chemkin to do that. I can do it just fine and I get reasonable results. But when I want to compare it against the experiments, I need to take the experimentally measured active catalyst sites into account. It's done by multiplying an F factor to the calculated rate of reaction at the boundaries with a catalyst. Since I don't have access to the boundary equations and species equations, what is the best way to add the experiment/geometry ratio factor?
I was thinking of multiplying the rate constant by the factor to increase/reduce the rate of the reactions.
Thanks a lot
mahmohammad is offline   Reply With Quote
Old   September 29, 2013, 16:01
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Originally Posted by mahmohammad View Post
Dear all,
Thanks a lot
Hi dude
If you mean to set the value for specific active area in surface reaction which has a unit (1/m), then you can access it from Cell zone condition/ (interest zone)/ reaction/ surface to volume ratio (1/m)
Hope it helps
Regard yours
A CFD free user is offline   Reply With Quote
catalyst reaction surface, chemkin-cfd, fluent, heterogeneous reaction
surface reaction UDF taekyu8 Fluent UDF and Scheme Programming 1 June 16, 2013 03:23
Surface reaction rate temperature dependence tumbao FLUENT 1 February 17, 2011 09:14
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
Surface Reaction Gabriella FLUENT 0 September 11, 2008 04:16
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
