Air at High Pressure
Old   September 29, 2013, 05:35
Default Air at High Pressure
cfd seeker is on a distinguished road
Hi Dear fellows
I am trying to model the Air Reducer/Pressure Reducer in Fluent. The Inlet pressure is 250 bars and mass flow rate is 0.36 kg/s. The desired outlet pressure is around 8-9 bars.
I am using Pressure inlet boundary condition @inlet and Mass flow inlet boundary condition @outlet(with appropriate direction vectors so that mass flow out from the outlet).
Since air is compressed at high pressure of 250 bars so Ideal gas model cannot be used. I have read that due to high variation of temperature from inlet to outlet Peng-Robinson Real Gas model should be used instead. But when I set this model in the materials panel for air and compute Reference values from the Inlet boundary, the density reported is very very less i.e of the orders of 10^-5. In actual scenario the density is high(around 300 kg/m^3) due to high pressure at which the air is stored in air bottles.
I don't know what mistake I am making....if any body has done such problem or has handled air at high pressures or used real gas models for air in Fluent kindly help me.
Thanks in advance.
Regards
cfd seeker is offline   Reply With Quote
Old   September 30, 2013, 07:49
like.no.other
like.no.other is on a distinguished road
Hi
I think you should use able-noble EOS in High pressure and temperature flow
www.CFDiran.ir
like.no.other is offline   Reply With Quote
Old   September 30, 2013, 14:58
Thanks for your reply.
Can you tell me what's the specialty of this model?
chtMultiRegionFoam solver application for high velocity& High Pressure xiaoyoyo OpenFOAM 2 July 25, 2013 11:50
how to replace a shock tube high pressure port by a boundary condition? immortality OpenFOAM Pre-Processing 0 May 2, 2013 13:43
Simulating movement of air from low to high pressure in Fluent jwillie2000 FLUENT 0 April 11, 2013 04:18
Simulating a high pressure flow through a valve Kromagnsss FLUENT 8 July 2, 2010 05:20
Properties of air versus temperature AND pressure Vincent Main CFD Forum 5 July 28, 2008 06:28
