October 6, 2013, 23:44 |
Pressure/Density Gradient
TX-Texas
Rep Power: 12 |
Is there a way to plot either pressure or density gradients in Fluent (Fluid)? Or obtain values for for pressure and density derivatives in respect to x, y and z directions, such as dp-dx, dp-dy and dp-dz?
October 8, 2013, 12:36 |
Gonzalo
yes, go to Plots under Results, then under Y Axis Function choose derivatives and the tipe of Derivative you want. Also yo have to select the lines over wich you want to calculate the gradients. Hope this helps you. Regards. Gonzalo
October 9, 2013, 11:43 |
TX-Texas
Rep Power: 12 |
Dear gfoam,
I do not see the "derivative" options under the "Y Axis Function." Do you think that I might be missing particular inputs? |
October 9, 2013, 14:42 |
Gonzalo
I don't know why you can't see that, but here you can see an image of it:
derivatives.png |
October 13, 2013, 21:13 |
TX-Texas
Rep Power: 12 |
Dear gfoam,
Derivatives is still missing from that section. I do not see it as one of my options. Do you think that I might be missing something in the setup stage? Since it is not working, is it valid to say that density in respect to the x direction is drho-dx since it is discretized? |
October 15, 2013, 07:47 |
Gonzalo
Hi, I'm confused. If you solved your problem (I mean, if you press Calculate and let the software run) you must see the Results/Plots task page. There you can find the derivatives of velocity and pressure, but there isn't a derivative of density. To plot the derivatives of density you can use CFDPost, but I don't how you can do this in that software. Another option you can use is, export the density along the line you want to, and numerically find the derivatives in a spreadsheet. i hope this helps you. Regards. Gonzalo
December 5, 2013, 22:17 |
TX-Texas
Rep Power: 12 |
Dear gfoam,
I went ahead and exported the pressure and density data to discretize them as dp/dx and drho/dx; however, I have no idea why derivatives do not show up (see figure). Do you happen to know why? |
ansys, density, fluent, gradient, pressure |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 23:34 |
vortex cause pressure gradient or pressure gradient induce vortex? | fruitkiwi | Main CFD Forum | 4 | June 12, 2012 02:12 |
can I use static enthalpy gradient to describe dT | Jay | CFX | 0 | August 7, 2008 00:01 |
How to compute gradient for non-orthogonal grids? | Paul Hsieh | Main CFD Forum | 3 | November 11, 2003 05:52 |
