October 8, 2013, 08:36 |
FLUENT solves faster when moving mouse??
Gary Galea
Rep Power: 12 |
Dear all, I noticed this today. I was doing a simulation of an infinitely long cylinder (2D) in crossflow from a tutorial.
What I noticed, is that, when moving the mouse in the FLUENT window, the solution time went down from 1:30:00 to about 00:05:00 and the solution did work out correctly as well as very short in time. Can anyone explain this or even prove it? I know it sounds ridiculous but it's true and I've been flabbergasted with it. I've even showed it to a friend of mine who has no explanation. Thanks all |
October 10, 2013, 02:14 |
Rep Power: 12 |
It's a sensational discovery!
October 10, 2013, 03:47 |
Gary Galea
Rep Power: 12 |
So do you agree with me that this is true?
October 10, 2013, 06:06 |
OJ
Rep Power: 20 |
Well there was a time when I used to think scrolling my download manager scrollbar accelerated the download
But probably all these are happy coincidences with different reasons? Is this phenomenon repetitive, for the same model and all other models you work on? OJ |
October 10, 2013, 06:19 |
Gary Galea
Rep Power: 12 |
Hi, yes I noticed it on other simulations such as an aerofoil. For the cylinder that I was testing, it definitely solved in shorter time and the result was also the same.
I was testing the tutorials found online from Cornell university |
October 10, 2013, 07:02 |
A-A Azarafza
Rep Power: 14 |
You are a genius man!
Regard yours |
October 10, 2013, 09:00 |
Philipp
Rep Power: 26 |
This is a well known bug, at least for the Ansys guys...
This can happen, when you start Fluent in workbench with multi-core. (At least in version 14.0). Just don't use workbench and you will be fine...
The skeleton ran out of shampoo in the shower. |
October 10, 2013, 10:47 |
Gary Galea
Rep Power: 12 |
Thanks a lot Philipp, that makes a lot of sense...
HELP - Moving car simulation in fluent | Brad Wells | FLUENT | 7 | January 4, 2018 19:55 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
moving wall at variable speed in Fluent | Kai Kang | FLUENT | 1 | November 26, 2012 03:43 |
Modelling Moving Boundary in Fluent | Felix Tae | Main CFD Forum | 0 | November 8, 2005 20:25 |
