-   -   Tracing the boundary layer development over a flat surface in natural convection (http://www.cfd-online.com/Forums/fluent/124693-tracing-boundary-layer-development-over-flat-surface-natural-convection.html)
Arvin October 10, 2013 21:43
I am working on natural convection over a flat plate. I created the geometry in gambit with face mesh with around 10,000,00 nodes. I am analysing 2d steady state but even after 10000 iterations, I am not able to get plumes moving up from bottom surface.Working fluid is water.Flux supplied to bottom plate( copper) is 500. Side walls are glass with temperature of 300K.Please do help me with your suggestions. Thanks!!
Bionico October 11, 2013 02:19
Hi Arvin,
check if you have turned ON gravity and if you have set up the density law (as a function of Temperature) in Materials Menu.
Kind Regards
Arvin October 11, 2013 09:39
Hi Bionico. I have set up density as Boussinseq approximation. Gravity is turned ON. I didn't attach a boundary layer mesh. Does it affect this problem?. The geometry is rectangle.
Bionico October 11, 2013 11:27
Yes, it may affect your simulation: you should have y+=1 in the first layer of boundary layer.
Kind regards
Arvin October 12, 2013 00:39
I have started the simulation using polynomial for density of water. The expression is 1000-0.02T. Currently I am using pressure based solver. Is it ok to continue the simulation?
Bionico October 14, 2013 02:18
I don't know if polynomial law is suitable for water (I assume that you already studied some books); the solver is ok. Go ahead! :)
Regards
