September 11, 2005, 21:48 |
Unsteady Jet Expansion
I'm a PhD student modelling the transient expansion of a jet into a region at significantly lower pressure. Has anyone done a simulation of this nature in the past? Also: is it possible to model a constant volumetric flow rate boundary condition in Fluent for a transient problem? At example would be using a rotary vane vacuum pump to evacuate a chamber. Cheers |
October 16, 2013, 04:12 |
tien
Rep Power: 12 |
Hi Hadley, have you found out the solution? I am doing the similar case and really want to know how to model it. thank you.
2D Plane Jet Fluent Solution | doug | Main CFD Forum | 11 | February 4, 2019 09:34 |
Free jet expansion | coastal593 | OpenFOAM Running, Solving & CFD | 6 | December 21, 2010 14:14 |
determination of jet front | Fred | CFX | 5 | February 11, 2007 12:01 |
method to determine jet front | Fred | Main CFD Forum | 0 | February 8, 2007 13:15 |
IMPINGING JET ........... HELP!!!!!!!! | Amir Omoumi | Main CFD Forum | 10 | August 30, 1999 22:11 |
