Create contour for variable already in source code (add UDM???) |
January 5, 2023, 13:48 |
Sean Small
Hi all, I am using the ANSYS Fluent PEMFC module and I would like to create a contour of the protonic conductivity. However this is not in the list of user defined memories that can be plotted, however it is being calculated in the source code as seen in the image attached.
Is there a way to plot this variable, I enabled effective MEA conductivity so it is being calculated. Do I need to add it to the list of UDMs? |
custom udm, fluent, pemfc model, udm |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
