Home > Forums > FLUENT
Execute command to change boundary condition
Old   October 17, 2013, 09:42
Default Execute command to change boundary condition
Aileen Magee
0906536m is on a distinguished road
I am modelling flow of a less dense fluid into tank full of a more dense fluid. I have defined the inlet zone as a velocity inlet and have set the desired velocity magnitude. The problem I am having is trying to change the velocity magnitude to zero after a certain number of time steps. I believe you use the execute command section within calculation activities, however I do not know what command to use. Any help would be appreciated!
0906536m is offline   Reply With Quote
Thread Tools
Trackbacks are On
Use DEFINE_ADJUST change boundary condition liurengtong123 Fluent UDF and Scheme Programming 24 August 1, 2014 10:28
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
