Running Ansys Fluent 14.5.7 with GPU mode
Hi ,
I am currently using Ansys 14.5.7 where I am currently using Dell T7600 Workstation(with single GPU).I have been able to run the GPU in Ansys Mechanical however I am unable to do so in Ansys Fluent. Any help in this regard will be highly appreciated. Thanking you. |
Fluent has pretty limited support for GPU computing; make sure it will help you before putting a lot of effort into it. As far as I know, it can only be used to calculate view factors and ray tracing unless you write a UDF specifically to take advantage of it.
