Accumulated variable
Old   October 23, 2013, 10:06
Default Accumulated variable
Select One...
eneja is on a distinguished road
Hi all!
I am carrying out a parametric analysis/optimisation for transient case and I would like to set accumulated heat/heat flow as my output parameter. For example: I have a storage unit and air is passing by. I set geometry, velocity and temperature of air at the inlet as my input parameters and want to optimise them so that the stored heat will be max. It means that values for each time step should be somehow stored and summed and then this value should be output parameter.
Any suggestions how to do it, because I am really stuck right now? With UDF or should I write expression in PostCFD?
Hope I was clear
eneja is offline   Reply With Quote
accumulated variable, optimization, output parameters
OpenFoam-1.6-ext Allwmake compilation error - one last barrier Pat84 OpenFOAM Installation 15 July 25, 2012 21:49
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
