Home > Forums > FLUENT
How to specify a mixture
Old   October 27, 2013, 11:11
Default How to specify a mixture
Aileen Magee
0906536m is on a distinguished road
For my simulation I need to create two materials for the porous zone ie the particle fluid and solid. The solid is a 3rd silicon and the rest oxygen, the fluid is salt water. When I go to create a user defined mixture I can select these materials, but how do I specify the volume fractions? In CFX you can simply specify your porous domain and then list the materials you require in the specified boxes and then their volume fractions.
Thank-you!
0906536m is offline   Reply With Quote
Old   October 27, 2013, 13:23
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
In Fluent, you need to know permeability(the inverse of viscous resistance) and porosity to be able to define porous media. Just define the corresponding zone in any preprocessor as fluid and then in cell zone condition, set the values for permeability and porosity. Besides, you can modify the properties for solid in porous media such as conductivity as well.
Regard yours
A CFD free user is offline   Reply With Quote
Old   October 29, 2013, 00:29
RossFS is on a distinguished road
I think you would have to do this at your inlet to the porous section (species tab). That is typically where I'm able to set the mass or molar fractions of the species in a mixture.
RossFS is offline   Reply With Quote
Thread Tools
Trackbacks are On
Mixture and Decay of a tracer in a Water Tank Jeffrey1992 CFX 2 July 27, 2012 13:31
mixture mass continuity eqn v.s. volumetric mixture continuity eqn kaifu ANSYS 0 June 9, 2011 08:42
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 08:14
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC richpaj OpenFOAM Bugs 2 October 9, 2008 22:14
Variable composition mixture .vs. reacting mixture Ting Wen CFX 0 January 7, 2008 07:04
