The end of unsteady flow
Old   October 29, 2013, 11:43
Question The end of unsteady flow
FHydro
flow_CH is on a distinguished road
Hi.
I am modeling an unsteady flow in fluent(implicit). With changing the time step, i can achieve to converging, but after converging the iteration is continue, so How can i understand the simulation is done and i can export the results?
Thanks
flow_CH is offline   Reply With Quote
Old   October 30, 2013, 00:42
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
by decreasing (I suppose) the time step size (dt), your solution converges faster FOR A TIME STEP (t). That means the solver switches on next time step (t+dt) untill time step t reaches the number of time steps you set (N)
In this example, dt = 5e-5 s
N = 2000
That means calculation will be over for t = N * dt = 2000 * 5e-5 = 0.1 s
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 30, 2013, 05:12
FHydro
Thank you for reply
1- In my case, by decreasing the time step size (dt), the residuals are going up and more diverge .
2- I do not anything about the time of ending the flowing in my model, so which time i should stop the processing?
Old   October 30, 2013, 05:26
-mAx-'s Avatar
Maxime Perelli
1- weird
2- it depends on what you want to compute (your physics)
Old   October 30, 2013, 05:41
FHydro
Can i stop processing when the results do not change after more iterations?
Old   October 30, 2013, 06:12
-mAx-'s Avatar
Maxime Perelli
For sure
(you should ask: "Can i stop processing when the results do not change after more time steps")
Old   October 30, 2013, 07:35
FHydro
I am asking: Can i stop processing when the results do not change after more time steps ?
Old   October 30, 2013, 07:44
-mAx-'s Avatar
Maxime Perelli
Originally Posted by -mAx- View Post
For sure
I already answered, so yes you can
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
error using combination of step function xujjun CFX 1 January 15, 2008 16:46
