January 15, 2017, 05:06 |
How to know the dimesnios from .cas file?
Rep Power: 9 |
Hello Dear,
Hope you fine and enjoying good health. I've a .cas file of a reactor. The reactor has two parts separated by one porous wall. I want to draw its exact geometry in Design Module but I don't know the exact dimension of the two parts. I can find the overall dimension of the reactor by SCALING it in GENERAL but the dimension of each part is unknown. If you know how can I find, please leave a comment. Thanking in anticipation. Omer |
January 16, 2017, 06:26 |
Bruno
Rep Power: 21 |
Open the cas/dat in CFD-Post. Export an STL of your geometry (File > Export > Export, Type = STL), import this STL back in DM. Now you can start recreating your geometry over the original one.
If you have access to it, use ANSYS SpaceClaim instead. It is much better for reverse engineering. |
January 17, 2017, 08:13 |
Rep Power: 9 |
Thank You So much Dear Brunoc.
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
