absolute pressure changing at the inlet
Old   October 11, 2013, 14:57
Default absolute pressure changing at the inlet
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
hey everyone,
I am launching a new case of simulation using the non premixed model. I fix my operating pressure to 366100 Pa. After some iterations, when i report the absolute pressure for the outlet, I found it to be 366100 Pa. and the inlet a little more higher. Why doesn't my inlet pressure equals 366100 Pa ?
thanks a lit
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   October 14, 2013, 06:03
OJ
oj.bulmer will become famous soon enough
If I am not missing something, isn't it obvious? Never used the non premixed model, but you would think that delta P across the inlet and outlet is responsible for flow?
oj.bulmer is offline   Reply With Quote
Old   October 15, 2013, 12:44
diamondx's Avatar
Ghazlani M. Ali
Thanks for your response,
Well , I was hoping to get a delta P of course, but since my inlet pressure is 366100 Pa, the outlet should be lower than that.
instead I'm getting the 366100 Pa at the outlet.
I want my air to enter at 366100 Pa. Not sure if I'm clear,
Thanks again
Regards,
Ali
Old   October 16, 2013, 09:46
François Grégoire
macfly is on a distinguished road
What are your BCs, velocity-inlet and pressure-outlet? Based on the pressure drop that you obtained, maybe you could set the inlet BC to pressure-inlet and the outlet to outlet-vent. In the outlet-vent settings, you adjust the Gauge Pressure according to the pressure drop you obtained initially, and Target Mass Flow Rate.
macfly is offline   Reply With Quote
Old   October 16, 2013, 14:42
diamondx's Avatar
Ghazlani M. Ali
Thanks francois,
the BC i used for the inlet is "mass-flow inlet", I could set the outlet-vent in the outlet like you said. But I also would like to validate the Delta-p of the experiments so I kept it pressure outlet.
If I were to switch to pressure-inlet. what gauge total pressure should I input knowing that the operating pressure 366100 Pa and that's what I want for my entering air ? I suppose it's zero. Can someone validate my saying ? Even with those entry my mass flow will not be the one I want. I'm missing something here.
Regards,
Ali
Old   October 16, 2013, 14:50
François Grégoire
Yes, gauge pressure 0 at inlet.
If you target mass flow rate at outlet and it converges to the targeted value, you will have the same mass flow rate at inlet. Even if there some fuel injection between inlet and outlet, you can do the calculation for the targeted mass flow rate at outlet. (unless there is some unknown infiltration/exfiltration...)
I have no idea if these settings converge well or not.
Keep me posted.
Old   October 16, 2013, 14:52
diamondx's Avatar
Ghazlani M. Ali
Great, I'll keep you posted.
Thanks a lot
Regards,
Ali
Old   November 5, 2013, 11:38
diamondx's Avatar
Ghazlani M. Ali
Everything work fine now. Thanks a lot !!!
Regards,
Ali
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 22:46
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 13:23
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Pressure inlet definitions Christian FLUENT 0 April 15, 2003 07:24
