Mass flow rate in plane
Like Tree2Likes
  • 1 Post By flow_CH
  • 1 Post By Zaktatir
Old   November 7, 2013, 04:04
Question Mass flow rate in plane
FHydro
flow_CH is on a distinguished road
Hello.
I want to know, can i obtain mass flow rate (report----> flux report) in new plane(not boundary) into the model?
Thanks
msasuzan likes this.
flow_CH is offline   Reply With Quote
Old   December 11, 2013, 15:41
FHydro
Please help
Old   December 14, 2013, 08:07
Zaktatir is on a distinguished road
Yes, create a surface plane then report the mass flow thourgh it
Zaktatir is offline   Reply With Quote
Old   December 14, 2013, 08:12
FHydro
Thanks but in that address we can just choose default boundaries not defined surfaces.
Old   December 14, 2013, 10:49
Surface Integrals you have to find it!
kad likes this.
Old   December 15, 2013, 21:45
Smile
Md Shahabuddin Ahmmad
msasuzan is on a distinguished road
Hi! flow_CH,
I think it is not possible to get the mass flow rate for a particular plane from the flux rather than boundry. and if you calculate the mass flow rate from the integral it will give you zero whatever the plane because of conservation of mass. what I suggest you is to take your desire plane from surface> plane>put co-ordinate/ alingned with surface (if so)..
Then go to Define>custome field function> from the drop down list: density*velocity (axial/y/total)> then creat.
now you can use report>surface integral>integral+custome field function+desired plane
cheers...
msasuzan is offline   Reply With Quote
Old   December 18, 2013, 07:31
Default velocity vectors
myaccount is on a distinguished road
Hi
I have simulated 2-D flow applying velocity inlet and pressure outlet boundary conditions.Later I applied periodic boundary conditions at inlet making the outlet conditions as shadow zone.After convergence, I see the velocity vectors coming out of the outlet zone.Why is this happening?
myaccount is offline   Reply With Quote
Old   January 7, 2014, 02:11
gsr_132 is on a distinguished road
Originally Posted by flow_CH View Post
Hello.
Thanks
In ANSYS CFX, you can create a plane in the goemtry by setting the distance from th origin as a reference and then use the inbuilt functions like mass avg,mass-area avg etc for finding the mass flow.
gsr_132 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Mass Flow rate through a plane titio OpenFOAM Post-Processing 9 August 22, 2017 03:46
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 16:22
Mass Flow Rate student87 CFX 4 January 2, 2010 04:45
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
