Problem in free surface modeling of water-oil mixture
Old   January 12, 2010, 02:24
Default Problem in free surface modeling of water-oil mixture
shahram
scythe is on a distinguished road
I want to model a free surface flow of oil-water mixture in Fluent. I have used VOF model, but I cannot set volume fraction of oil in water when I enable open channel option.
Any help would be highly appreciated
Regards
scythe is offline   Reply With Quote
Old   January 12, 2010, 09:18
Default Free surface flow
CFDtoy
CFDtoy is on a distinguished road
Hi ,
Do want to keep oil and water separate and simulate the interfacial dynamics? or you have a "mixture" of oil and water and you want to simulate the interface between oil-water mixture and some gas around?
For, initializing oil in water etc..you may want to use the "patch" option - select cells with water and patch vf of oil in those regions.
Thanks,
CFDtoy
visit http://cfdtoy.blogspot.com
Regards
CFDtoy is offline   Reply With Quote
Old   January 12, 2010, 09:53
shahram
Originally Posted by CFDtoy View Post
Hi ,
Thanks,
CFDtoy
Thanks for the reply
The inlet boundary condition is an immiscible mixture of water and oil, for example an oil with 200 ppm water as the inlet flow enters the domain with velocity of 0.7 m/s, and as you know because of the difference between the densities of oil and water, the oil phase tends to move upward and this effects the velocity profile. All I want is to find the velocity profile at different sections.
I am looking forward to hearing from you soon
Thanks again
Old   January 12, 2010, 10:21
Default oil problem
CFDtoy
For this try eulerian-lagrangian type modeling with buoyancy effects. You are looking at more the averaged distribution of the fractions and their effect on velocity profile. Eulerian modeling will give you that - inclusive of velocity difference.
but again, if you think this is a dilute assumption: use Eulerian-lagrangian type modeling and treat the dispersed part (water droplets) as embedded in the continuous (oil) flow and track their behavior.
you dont need VOF to get the interface tracking or capture the droplets ..its may consume too much comp resources and time.
I have posted an entry on my blog concerning doing Eulerian-Lagrangian modelign and where it should be considered.
Thanks,
CFDtoy
Visit http://cfdtoy.blogspot.com
Thanks again
Old   November 12, 2013, 11:47
Dimitris Romanas
Volumeoffluid is on a distinguished road
Hi all,
the line between oil-water how did you define this??
as wall??as what and with what specifications?
Thank yoU!
Volumeoffluid is offline   Reply With Quote
Modeling Condensation in water vapour-air mixture Amol Main CFD Forum 14 April 10, 2012 00:28
Free surface modeling Bruce CFX 4 July 19, 2007 15:00
The problem of modeling free jet with VOF river FLUENT 0 December 27, 2005 02:29
modeling the mixture of fresh and saline water francisco tovar CFX 3 April 19, 2005 12:44
best package for free surface problem? Juan Main CFD Forum 1 October 29, 1999 18:51
