Stirred tank Using MRF
Like Tree1Likes
  • 1 Post By ghost82
Old   November 11, 2013, 04:55
Default Stirred tank Using MRF
Gurpreet
gurpreet89 is on a distinguished road
[LEFT]hi friends,
i am working on stirred tanks (baffled) with rushton turbine using multiple reference frame for my project work. I am very new to the fluent. i have made the geometry of stirred tank in designmodeler ,i have created an interface between the rotor(moving region) and fluid(stationary region). Now when i am rotating the fluid in contact with the impeller at 180 rpm, keeping the impeller and the outer fluid stationary i am getting the vector plots as given in pictures
as the fluid crosses the interface it changes its direction, why is it happening?? plz help
gurpreet89 is offline   Reply With Quote
Old   November 11, 2013, 07:09
ghost82's Avatar
Rick
ghost82 will become famous soon enough
check your cell zones; assign to rotor zone absolute rotational velocity of xxx rpm; make stator zone stationary; in boundary conditions set shaft+impeller walls rotating at a relative rotational velocity of 0 rpm and to baffles/tank absolute velocity of 0 rpm.
PS: positive rotational velocity means conterclockwise rotation
Daniele
ghost82 is offline   Reply With Quote
Old   November 14, 2013, 02:26
Default thanks for the reply
Gurpreet
Actually there are many walls in my case in the 'boundary conditions' i dont understand which one is for rotor and which one is for baffle. i used display option to show those walls but it is not showing any. dont know whether there is any mistake in my geometry.
i iterated it for 1500 iterations but after around 1000 graph becomes constant.do i need to iterate more to get better results?
can you send me one of your example so that i can compare?
gurpreet89@gmail.com
Old   November 14, 2013, 03:14
ghost82's Avatar
Rick
Then, turn back on your geometry and fix it.
An example of mrf is from Mr. Bakker,
Stirred tank flow field model
http://www.bakker.org/dartmouth06/engs199/
Daniele
Old   November 16, 2013, 08:46
Gurpreet
thanks for replying, i visited bakker's website. He is a very well known personality in the field of stirred tanks and CFD. i downloaded his one of the homework file 'pbt.msh.gc' . i imported that file then putted the same boundary and cell conditions as you told
in cell zone conditions - gave fluid-impeller the 'absolute' volcity of 30 rpm and kept fluid tank as stationary.
in boundary conditions - gave relative velocity 0 to the impeller and shaft, and 'absolute' velocity 0 to baffles and tank wall.
i used 'coupled' discretisation method and did hybrid initialization, result i am getting as below
above image is streamline view
contours (top view)
vectors
as in my case, the vectors inside the rotating zone are moving in opposite direction to the stationary zone. plz help
Old   November 16, 2013, 08:52
ghost82's Avatar
Rick
can you plot velocity in stn frame in cfd post?
Daniele
Old   November 16, 2013, 09:41
Gurpreet
yes ,now i am getting in the same direction
thank you very much
Old   November 16, 2013, 09:54
ghost82's Avatar
Rick
Just for your info, when you plot velocity in stn frame you have velocity with regard to a stationary frame.
When you plot velocity you have velocity with regard to the moving frame.
Daniele
villager likes this.
Old   May 14, 2014, 11:36
solmaz aryafar
solmaz aryafar is on a distinguished road
Hello Daniele and gurpreet89,
First orf all thanks for the useful topic!
I have a question!!
I tried the same example as you were talking about above (pbt.msh.gz) , and I don't get the convergence at all. I used the same cell zone conditions and boundary conditions, and just one thing I'm not really sure about is the "direction of rotation" which I selected it to be (1 0 0), is that correct?
So why my solution doesn't converge???
Actually I tried this example, because I have the same problem with my own example, which is a stirred tank as well.
Please help me, I'm running out of time!
Thanks in advance,
Solmaz.
solmaz aryafar is offline   Reply With Quote
Old   May 17, 2014, 23:20
Gurpreet
hi,
(1 0 0) means rotation about x-axis, similarly (010) fr rotation about y-axis and (001) about z-axis. If the shaft of the impeller is in X direction then take (100) but i think in that example the it was (001).
Gurpreet
Old   May 20, 2014, 08:32
solmaz aryafar
Hello Gurpreet,
Thanks a lot for your answer! I guess now it's getting better, but no in that example the shaft was in the direction of x-axis
Look, I have a question here from you, because as I saw in the forum you work (or worked) on stirred tank simulations, am I right? So here I have a problem!
I created a mesh in Ansys Meshing for my stirred tank which have pitched blade impellers, and I used MRF approach, but I had issues in convergence, I mean the solution did not converge! As I showed the mesh to an expert (which I couldn't reach anymore unfortunately) he said that the quality of mesh is not good, and that I need to try Sliding Mesh approach. Then I researched a little bit in forumes, and also teh website of Prof. Bakker, and now it seems to me that I need to mesh the part arround the impellers with structured cells as the rest of the tank, am I right? so does it mean that I have to use sweep mesh for this part? I imagined like that, so I tried to mesh this part with sweep methos but the Ansys Meshing complains and says: "this part is not sweepable. So my question is that, I need to use ICEM instead of Ansys Meshing? I mean it's not possible to make sweep meshes arround a complex geometry (like the impellers) with Ansys Meshing?
I will appreciate your (or any one else's) help!
Solmaz.
Old   May 26, 2014, 10:33
Gurpreet
hi,
what convergence criteria you are following, 10^-3 or 10^-4 ?
In my case, i was able to converge it to 10^-3 using ansys meshing and went closer to 10^-4. i made my rotor and baffles as structured but for fluid zone i used tetrahedral (unstructured).
may be your results are not converging due to some geometry issues, if you want your results to be very accurate with error less than 10- 5 % or so,then you can go for ICEM.
Results don't vary much either you use MRF or SM, lot of journals are there on the same.
[GAMBIT] geometry and griding a stirred tank prec ANSYS Meshing & Geometry 12 May 22, 2014 12:46
[Design Modeler] Stirred Tank using MRF gurpreet89 FLUENT 2 October 6, 2013 14:02
Monitoring Convergence in Stirred Tank using MRF method GOPINATH87 Main CFD Forum 0 August 19, 2011 23:45
Stirred tank using MRF dishengbin FLUENT 14 March 13, 2011 22:11
CFX 5.5.1 stirred tank and LES problem Nishant CFX 2 September 13, 2002 07:11
