Fuel cell I-v Curve
Like Tree7Likes
  • 1 Post By A CFD free user
  • 3 Post By A CFD free user
Old   November 14, 2013, 00:27
Default Fuel cell I-v Curve
Alireza Setayesh Hagh
Aliset1236 is on a distinguished road
Hi
I am trying to plot I-V curve for fuel cell is there any one who can help me in this respect
Aliset1236 is offline   Reply With Quote
Old   November 15, 2013, 06:11
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi Buddy,
It's an easy work. Impose the appropriate value for voltage on cathode wall terminal and calculate the corresponding current density. You need to do the same procedure for a few points. Then plot the values. Just keep in mind that, start from a voltage near to open circuit voltage and decrease it as e step function.
I hope it helps
bin279 likes this.
Regard yours
A CFD free user is offline   Reply With Quote
Old   November 15, 2013, 09:12
dear sir
Thank you very much
1-But why I should start from Open circuit voltage
2-what do you mean by"Just keep in mind that, start from a voltage near to open circuit voltage and decrease it as e step function.
Old   November 15, 2013, 12:05
A-A Azarafza
Originally Posted by Aliset1236 View Post
dear sir
Thank you very much
It turns out you didn't take my points. I meant, to plot a I-V curve, you need to do simulation at least for a few points, right? For instance, let say V=0.9, 0.8,0.7,0.6,0.5, 0.4 , ...
So, you must calculate the corresponding current density, respectively. By saying the above statement, I meant that you start from 0.9 (near to Open circuit ) and obtain its current density, and then go to 0.8 and obtain the current density for this too and so forth. As you see, it's like a step function with magnitude of 0.1.
Regard yours
Old   January 5, 2015, 15:22
Default polarization curve.
hadjadj
razika is on a distinguished road
please. any one can tell me about ploting cell potential curve versus current density (V-I). what is the relation between thses two entity? and how can I plot it in fluent 6.3
sincerly.
razika is offline   Reply With Quote
Old   January 12, 2015, 11:00
A-A Azarafza
sincerly.
it's not a difficult thing. To plot a current-voltage (I-V) in Fluent, you only need to specify one of these two mentioned properties as BC at cathode wall terminal, (potentiostatic or galvanostatic). Let's say that you select potentiostatic, it means that you prescribe the value of voltage at cathode and receive the report calculated value of current density in Fluent console. You got the current density for a specific potential. Now, you need to repeat the same strategy for the next value of voltage. Performing this in a range of values, lets say voltages between 0.9 to 0.2, you got the corresponding values of current density and there you go, your current density vs voltage curve is ready to plot. It's straightforward and facile.
ramakant, yun1ksu and bin279 like this.
Regard yours
Old   April 15, 2015, 13:15
Yunus
yun1ksu is on a distinguished road
Thank you so much I've been looking for this.
yun1ksu is offline   Reply With Quote
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
PEM fuel cell simulation pchoopanya Mesh Generation & Pre-Processing 1 February 29, 2016 23:56
Charge Transport for Fuel Cell Applications Jallen13a FLUENT 1 April 3, 2012 05:32
Fuel Cell Orb FLUENT 0 February 27, 2012 12:55
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
