November 14, 2013, 19:25 |
Fluctuations using LES
starter
Rep Power: 15 |
Hi
I am using Fluent to capture pressure fluctuations in a developed turbulent flow. I have two geometries, pipe elbow and tee. I had been using openfoam and it would give pressure fluctuations at probe locations at every time step which would constantly fluctuate in time whereas in Fluent, they die in developed flow and flow becomes steady. I am taking different types of Surface Monitors. "Integral, Area-weighted-average, Sum" of "Static and Total pressures both" but to no avail. I am using Smagorinsky Model with Velocity 75 m/s and using No perturbations method. Also I am using Sampling from command line for those points but somehow I cannot execute compute-sample in report and plot both, Can someone please write the whole syntax. Best Regards |
pressure fluctuations, sample, turbulence |
OF2.1: turbulentInlet for LES, description of how the fluctuations are generated | Jan.Östh | OpenFOAM Running, Solving & CFD | 14 | November 26, 2019 16:57 |
(u' v' w') write velocity fluctuations in LES? | owayz | OpenFOAM Running, Solving & CFD | 1 | December 17, 2012 12:58 |
Inlet fluctuations issue in LES | Ivan | Main CFD Forum | 0 | October 15, 2012 12:57 |
Random fluctuations at the inlet boundary for LES | underGroundMan | CFX | 3 | November 19, 2010 11:11 |
Random fluctuations on LES flow | cfd novice | CFX | 0 | July 3, 2008 10:39 |
