udf error
Old   June 6, 2011, 23:33
Default udf error
raymond
wlt_1985 is on a distinguished road
I am new in using udf in fluent. I wrote udf to define properties of individual materials and their mixture. Some examples are shown as below:
DEFINE_PROPERTY(nitrous_oxide_viscosity, c, t)
real E; /* self-defined variable for convenience */
real mu; /* calculated viscosity in unit kg/m.s */
real T = C_T(c,t); /* temperature in unit kelvin, K */
const real A = 0.4733; /* dimensionless regression coeficient */
const real B = 21.8; /* dimensionless regression coeficient */
const real C = -0.004923; /* dimensionless regression coeficient */
const real D = -0.000004274; /* dimensionless regression coeficient */
E = A + B/T + C*T + D*T*T; /* self-defined variable for convenience */
mu = 0.001*pow(10, E); /* calculated viscosity in unit kg/m.s */
return mu; /* calculated viscosity in unit kg/m.s */
DEFINE_PROPERTY(mixture_thermal_conductivity, c, t)
real sum = 0.0;
int i;
Material *sp;
real ktc;
Property *prop;
mixture_species_loop(THREAD_MATERIAL(t), sp, i)
prop = (MATERIAL_PROPERTY(sp));
ktc = generic_property(c, t, prop, PROP_ktc, C_T(c,t));
sum += C_YI(c,t,i)*ktc;
return sum;
Error appears for simulation. 1 1.#QNBe+00 is shown for all residuals.
I did a check and found that udf causing the error. Can pls help me to check is there any mistake to my udf? I totally do not know what wrong is going on. Pls help.
Thanks for help.
wlt_1985 is offline   Reply With Quote
Old   November 15, 2013, 08:51
Unhappy
mehdimoradi
mehdimoradi. is on a distinguished road
Hello raymond
Could you sloved the problem associated with UDF?
I encountered with the same problem in running of species transport UDF. all of iterations are converged but donot display the residuals. in addition to .QNBe+00 is appered in the iterations.
Can you help me?
Thanks.
mehdimoradi. is offline   Reply With Quote
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
