is it necessary to multiply by number of blades with moment to calculate the power?
Old   November 16, 2013, 05:48
Default is it necessary to multiply by number of blades with moment to calculate the power?
ijaz fazil
er_ijaz is on a distinguished road
Hi
I have done the simulation of wind turbine using MRF analyis. I have not done any symmetric analysis. I have done whole blade simluation. But when I calculated power, it is half the value. My friends suggested that I should multiply by number of blades to calculate the power from moment value?
Is it so?
er_ijaz is offline   Reply With Quote
Old   November 16, 2013, 08:35
ghost82's Avatar
Rick
ghost82 will become famous soon enough
if you simulated the whole 3d model you have not to multiply by the number of blades; you have to multiply only if you do periodic simulations.
Daniele
ghost82 is offline   Reply With Quote
Old   November 16, 2013, 19:04
Default Hi, then do u have an idea where i'm going wrong
ijaz fazil
Hi
I run two simulations one fo 7 m/s and another for 10 m/s. In both cases my power is half of the experimental.
I think I have a problem with direction of rotation. I have a doubt while using thumb rule, index finger should be pointed from inlet to the blade or the index figer should point from blade to inlet
power, torque, windturbine
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
calculate pitching moment coefficient jyh3134 FLUENT 0 January 30, 2013 10:40
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
How to calculate inlet swirl number in Post? CFXPostuser CFX 8 April 29, 2009 13:50
Calculating pitching moment for power input Zonexo Main CFD Forum 0 June 12, 2008 06:07
