Home > Forums > FLUENT
Laminar Flow
Old   November 23, 2013, 13:18
Default Laminar Flow
asdasdasd
parradux is on a distinguished road
My objective is to obtain the pressure drop and mixing index of a non-newtonian fluid through a pipe with some obstructions placed within the pipe.
In order to develop the mixing index I want to mix two of the same fluid (so they are miscible) within the pipe. My first question is what model do I use to mix two fluids? I've been using multiphase mixture however I do not know if this is a good solution because it sometimes gives me errors for my pressure correction. Do I select species transport and or do I use both of these or do I use something else entirely.
My second question which is somewhat related to the first - for my geometry I only have one body: how can I make two fluids flow through one inlet?
Instead of simulating two of these fluids can I patch or inject the same fluid into my inlet and at the end of my simulation how can I look for the properties (velocity, pressure, flow, etc) of said patch/injection?
Thank you,
parradux is offline   Reply With Quote
Thread Tools
Trackbacks are On
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 07:45
laminar and turbulent flow in two regions mozafarie FLUENT 0 March 11, 2013 14:42
How to enforce laminar flow while using k-e Grzegorz Kondora FLUENT 0 January 28, 2009 11:35
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
