April 21, 2013, 14:18 |
energy source term for phase change
mehrdad
Rep Power: 15 |
hi everyone
i'm simulating a converging-diverging nozzle saturated water enter and because of pressure drop flow changes to two phase and the temperature decrease.for evaporation & condensation i use evaporation-condensation model in ansys fluent 13 with T_sat varying by pressure and i use a source term to add latent heat to energy equation and i use mixture model but when i run the case the fluent says : Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f here is my udf's: #include "udf.h" DEFINE_PROPERTY(T_sat,c,t) { real T,p; p=(C_P(c,t)*7.501*0.001)+0.057; T=5132./(20.386-log(p)); return T; } DEFINE_SOURCE (phase_change,c,t,dQ,eqn) { real a,b,Tsat,T,h,Q,p1,m_net; Thread *tm=THREAD_SUPER_THREAD(t); Thread **pt = THREAD_SUB_THREADS(tm); Thread *tp = pt[0]; /*primary phase*/ Thread *ts = pt[1]; /*secondary phase*/ p1=(C_P(c,t)*7.501*0.001)+0.057; Tsat=5132./(20.386-log(p1)); T=C_T(c,t); if(200.<T<272.7) h=2835000.; /* latent heat(j/kg)*/ if(272.7<T<500.) h=(-0.004*pow(T,2.)+0.492*T+2681.)*1000.; a=0.1; b=C_VOF(c,ts)*C_R(c,ts)-C_VOF(c,tp)*C_R(c,tp); m_net=(a*b*(T-Tsat)/Tsat) /*mass transfer(kg/m3s)*/ Q=m_net*h; if(272.7<T<500.) dQ[eqn]=a*b*(h/Tsat+(-0.008*T+.429)*(T-Tsat)/Tsat); else dQ[eqn]=a*b*h/Tsat; return Q; } |
May 31, 2013, 11:24 |
Mahboobe Mahdavi
Rep Power: 13 |
Hi can I have your email address? I am working on evaporation condensation problem I have some question.
Thanks |
June 3, 2013, 14:54 |
mehrdad
Rep Power: 15 |
what is your question ?
November 26, 2013, 12:50 |
meisam
Has your problem solved Mr koochaki?
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
UDF for energy source | João Fernandes | FLUENT | 4 | October 17, 2008 04:53 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
linearization of radiative energy source term | Nuray Kayakol | Main CFD Forum | 0 | May 7, 1999 08:11 |
