Home > Forums > FLUENT
Divergence (pressure correction) for axysymmetric density driven flow
Old   November 29, 2013, 19:33
Default Divergence (pressure correction) for axysymmetric density driven flow
Sxq
Sxq is on a distinguished road
Hi!
I'm trying to simulate an unsteady density driven/negative buoyancy event where I have a volume of low density ambient fluid, and a smaller cylindrical volume of more dense fluid which is initialized inside the ambient fluid and released. There is no forcing other than the density difference, and the idea is that the volume of dense fluid will fall downward and hit the bottom wall of the region.
I made a 2D axisymmetric domain with one of the side walls having an axis BC, the other side wall being a pressure outlet, the top being a pressure outlet, and the bottom being a wall.
I used the Eularian 2 phase model to define both liquids.
I'm using the SST k-omega turbulence model.
However the solution diverges as soon as I start trying to solve. I think it has something to do with my BCs... It doesn't seem to like the way I have set up the axisymmetric condition perhaps? I am able to run a similar flow condition when I approximate it as a 2D planar flow instead.
Any help on why it diverges, or confirmation that the models I'm using are valid would be great... Here is a schematic of the domain:
http://imgur.com/Wqsc2l1
Sxq is offline   Reply With Quote
Old   November 30, 2013, 08:28
flotus1's Avatar
Alex
flotus1 will become famous soon enoughflotus1 will become famous soon enough
Does your axis boundary condition coincide with the x-axis?
Fluent can only handle axisymmetric flows with this domain orientation.
flotus1 is offline   Reply With Quote
Old   November 30, 2013, 17:56
Sxq
My axis boundary condition is coincident with the y-axis. Will this actually cause it to not work?
Old   November 30, 2013, 19:39
Sxq
Yep... it only works along the x-axis... Thanks. Now I just need to figure out the smaller details, but it seems to be running well.
Thread Tools
Trackbacks are On
Divergence detected in AMG solver: pressure correction thisisit FLUENT 8 March 2, 2016 16:20
Divergence detected in AMG solver: pressure correction xinquanzhoucn FLUENT 5 July 21, 2014 04:49
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 4 July 21, 2013 16:24
Help! Divergence detected in AMG solver: pressure correction user0314 FLUENT 3 September 2, 2011 16:12
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
