co-axial double pipe heat exchanger
Old   December 3, 2013, 23:29
Default co-axial double pipe heat exchanger
manish
manish285 is on a distinguished road
i am following a tutorial on double pipe exchanger available athttp://homepages.wmich.edu/~leehs/ME...20tutorial.pdf
i have tried lot of time but the solution doesnt converges but the tutorial says it should converge within 650 itrations.
i need help to simulate double pipe in ansys fluent
please help
manish285 is offline   Reply With Quote
Old   December 4, 2013, 03:34
Vignesh KPV
vigii is on a distinguished road
Send a message via Skype™ to vigii
Did you follow up the same steps as per the tutorial.
Changing mesh sizes would also affect the convergence
vigii is offline   Reply With Quote
Old   December 4, 2013, 04:04
manish
Yes i have done the meshing as per instruction but solution not converging...recomend me some other tutorial , if you know any
[ANSYS Meshing] double pipe heat exchanger meshing in ICEM CFD chitra ANSYS Meshing & Geometry 0 April 13, 2013 08:36
Linux vs PC Compiling Rhyno466 Fluent UDF and Scheme Programming 10 May 11, 2012 17:01
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
pipe in pipe heat exchanger JohannV FLUENT 3 December 3, 2009 02:53
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
