December 12, 2013, 09:02 |
#21 |
Rep Power: 12 |
RodriguezFatz sorry sir now i understand,
the value comes out to be estimated wall distance 5.0e-7. i had taken fluid as incompressible but fluid releasing flow rate is very high so velocity comes out to be very high. Zaktatir sir,installations modeled in your tunnel means? |
December 12, 2013, 13:01 |
#22 |
Rep Power: 17 |
Something in the tunnel
Have you monitored what i asked for yesterday! |
December 12, 2013, 13:40 |
#23 |
Rep Power: 12 |
Zaktatir
Sir I had decreased the viscosity value in limits, I thought it would decrease the turbulent viscosity ratio. But viscosity ratio value remains as it is and then inc further. |
December 12, 2013, 13:51 |
#24 |
Rep Power: 17 |
you have to increase it! Then monitor the ratio
December 12, 2013, 13:59 |
#25 |
Rep Power: 12 |
Okay sir, I will do it tomorrow..
Thankyou for the response.. |
December 12, 2013, 23:59 |
#26 |
Rep Power: 12 |
vicosity ratio now increased to 1.0000e+007 in 348 cells.
December 13, 2013, 06:15 |
#27 |
Rep Power: 17 |
As i said you have to increase it to very high level and then monitor the ratio because i made several Full Scale simulations and it is normal to get very high levels. When the ratio is constant than that is OK if not we have a problem with setup!
Make this and post us your turbulence specifications and models used! |
December 13, 2013, 06:23 |
#28 |
Rep Power: 12 |
viscosity ratio limited to 1.00e007 in352 cell then become constant ..is that okay??
December 13, 2013, 06:27 |
#29 |
Rep Power: 17 |
You have to monitor the max value of that ratio in your domain |
December 13, 2013, 08:20 |
#30 |
Rep Power: 12 |
Okay sir, I will update progress soon ,
you are so kind.. Last edited by annu; December 14, 2013 at 05:31. |
December 14, 2013, 05:30 |
#31 |
Rep Power: 12 |
Zaktatir
sir viscosity ratio value disappear when i increase the limit to avery high value..does it come again or is it vanished finally? |
December 15, 2013, 08:41 |
#32 |
Rep Power: 12 |
Zaktatir
i had increased the viscosity limits, it means fluent will not act upto this limit,,means problem is still there?? |
December 15, 2013, 10:06 |
#33 |
Rep Power: 17 |
As i said a couple of times you have to monitor the value of the ratio and describe the behavior of it.
December 16, 2013, 23:18 |
#34 |
Rep Power: 12 |
Zaktatir
hi.. sir, turbulent viscosity ratio value is varying. |
December 17, 2013, 08:48 |
#35 |
Rep Power: 12 |
help me friends..its really urgent.
December 17, 2013, 10:10 |
#36 |
Rep Power: 26 |
Zaktatir is giving you some good advice, and is/was really trying to help you.
If your problem is really urgent, I suggest that you read his posts more carefully, so he does not have to ask the same thing several times, that would save a lot of time. |
December 17, 2013, 15:38 |
#37 |
Rep Power: 17 |
How high are the variations please post the outfile of the ratio with good scaling
December 19, 2013, 00:18 |
#38 |
Rep Power: 12 |
turbulent viscosity limited to viscosity ratio of 1.000000e+018 in 34 cells
iter continuity x-velocity y-velocity z-velocity energy k epsilon cl2 time/iter 15186 6.8167e+03 3.3742e-02 2.4911e-02 4.4437e-02 1.4350e-16 2.4341e-03 1.4332e-02 6.2606e-03 0:00:26 9 reversed flow in 349 faces on pressure-outlet 6. turbulent viscosity limited to viscosity ratio of 1.000000e+018 in 50 cells 15187 6.5498e+03 5.7507e-02 6.0878e-02 6.6267e-02 1.4299e-16 4.9059e-03 1.3393e-02 1.1456e-01 0:00:23 8 reversed flow in 348 faces on pressure-outlet 6. turbulent viscosity limited to viscosity ratio of 1.000000e+018 in 16 cells 15188 6.3025e+03 4.1791e-02 4.3380e-02 3.6034e-02 1.8478e-16 3.3064e-03 1.2526e-02 4.5538e-02 0:00:21 7 reversed flow in 346 faces on pressure-outlet 6. turbulent viscosity limited to viscosity ratio of 1.000000e+018 in 8 cells 15189 5.8987e+03 2.3631e-02 1.7922e-02 2.2339e-02 1.9696e-16 5.1657e-03 1.1816e-02 9.5634e-02 0:00:16 6 reversed flow in 345 faces on pressure-outlet 6. turbulent viscosity limited to viscosity ratio of 1.000000e+018 in 4 cells 15190 5.6010e+03 1.2755e-02 9.1244e-03 1.5703e-02 1.9470e-16 2.5350e-03 1.0967e-02 1.9807e-02 0:00:14 5 reversed flow in 345 faces on pressure-outlet 6. |
December 19, 2013, 00:21 |
#39 |
Rep Power: 12 |
hii Zaktatir.
values are not stable, sometimes they disappear and they reappear. |
December 23, 2013, 05:22 |
#40 |
Rep Power: 12 |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
problems running fluent through matlab | galapago | FLUENT | 1 | October 10, 2013 09:20 |
Aeroacoustic Problem (Modeling Flow-Induced Noise Problems Using FLUENT) | cici | Main CFD Forum | 0 | September 29, 2011 14:28 |
Problems with FLUENT MPI on i7 2600K/P8P67 | TaurusASV | FLUENT | 1 | May 5, 2011 11:58 |
Problems with Fluent | Jacek | Main CFD Forum | 2 | August 16, 2002 04:14 |
