Home > Forums > FLUENT
fluent problems
Like Tree1Likes
Old   December 10, 2013, 05:58
Default fluent problems
annu is on a distinguished road
hi friends,
i am doing my project based on species transport without reaction. Its basically release of gas through a tunnel of 1200 m. i am taking pressure based solver,unsteady state,k-epsilon model(2 eq) ,pressure velocity coupling---PISO,first order upwind. step size=0.01 max iteration per time steps is 20...when i run these it says "turbulent viscosity limited to viscosity ratio of 1.0000e+005 in 6328 cell". i had refined the grid but problem remains the same.
gas is released through a 180mm hole. flow rate is very much high. i am taking fluid as incompressible.
please help me friends, its urgent
thankyou in advance..
CJBai likes this.
annu is offline   Reply With Quote
Old   December 10, 2013, 08:44
misterdd
misterdd is on a distinguished road
try to change air viscosity to sutherland instead of constant value. hope this will help your problem.
misterdd is offline   Reply With Quote
Old   December 10, 2013, 08:48
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Sometimes this is due to bad initialization and the warning will vanish after a few time-steps. Do you "need" the first time-steps or could you just run the simulation and start evaluating later?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   December 10, 2013, 11:29
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
Following RodriguezFatz advice, what about to calculate a steady state solution with only air and then change the injection of air with your tracer?
Daniele
ghost82 is offline   Reply With Quote
Old   December 10, 2013, 11:58
I had firstly run the simulation without tracer in steady state for 240 sec Then I inject the tracer.
I had changed thermal conductivity and viscosity to ideal gas mixing law.warning is same. Turbulent viscosity is not disappearing after 200000 iterations.
Thankyou all for your responses..
Please help.
Old   December 10, 2013, 12:59
Zaktatir is on a distinguished road
-Look after the inlet / outlet specification of your turbulence unerliying properties for the calculation of the kinetic energy and turb. dissipation. Use middle intensities and viscosity ratios. Start first of all with first order turbulence handling and then monitor the ratio to see whether your simulation iw q kind of fullscale simulation where you may expect very high ratio of turb. to molcular viscosity
Zaktatir is offline   Reply With Quote
Old   December 11, 2013, 01:32
Zaktatir , i am using turbulent intensity and hydraulic diameter as specification method for inlet and outlet.
from 240 sec i mean i had run for a week then injected tracer.
misterdd- i had changed it to sutherland viscosity, but viscosity in number of cells is increasing. no impact.
Old   December 11, 2013, 03:52
Philipp
Look at the results: Where does the viscosity limiting occur? At the inlet / outlet / at some corners?
Old   December 11, 2013, 04:31
RodriguezFatz...
sir, u mean plotting the countours of turbulent viscosity ratio?
I had plotted, it shows red colour contours means maximum at velocity outlet that is from hole from gas is leaking..
I had again meshed the grid by taking more interval counts for hole..results are same..
Philipp
Can you post the pictures?
Old   December 11, 2013, 05:55
sir it exceeds the limit of 97.7
Old   December 11, 2013, 06:48
sir had attached ..
Old   December 11, 2013, 06:53
Philipp
1) What's your y+?
2) I can not see the problematic regions in the pictures, since you limited the scaling to 1. Where is it 1e5 ?
Old   December 11, 2013, 08:12
y is height of tunnel. i.e 7m
Old   December 11, 2013, 08:21
Philipp
y+ is the solution of the numerical grid at the wall. You need to plot it on the wall.
Old   December 11, 2013, 08:27
sir,I dint get U. I am new to fluent. Please explain.
Old   December 11, 2013, 08:30
Philipp
This is too substantial to be explained in the forum. You should get some basic CFD book and try to understand it before starting with simulations. "y+" will be explained in every good book.
Old   December 11, 2013, 08:52
mine problem is turbulent viscosity ratio is not disappearing after so many iterations.
Old   December 11, 2013, 08:55
vertical plane which i made is middle of tunnel and also it is centre of sqaure shaped hole mm dimension
y is height
and z is length
and x is width
Old   December 11, 2013, 13:57
1/familiarize your self with basic turbulence modeling and understanding
THAT IS THE MOST IMPORTANT POINT IF YOU WANT TO UNDERSTAND WHAT ARE YOU SIMULATING
2/For full scale geometry is possible to get very high ratio: I simulated a Train and the ratio was above 10 power 8. The large scale of the eddies are dependent on the geometry
3/Monitor the viscosity ratio after increasing the limit of it (let say to bigger value than the limit)
4/Look whether the value is converging to a constant range: if not you have a problem
5/Do you have any installations modeled in your tunnel
Thread Tools
Trackbacks are On
problems running fluent through matlab galapago FLUENT 1 October 10, 2013 09:20
Aeroacoustic Problem (Modeling Flow-Induced Noise Problems Using FLUENT) cici Main CFD Forum 0 September 29, 2011 14:28
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 0 August 5, 2011 16:02
Problems with FLUENT MPI on i7 2600K/P8P67 TaurusASV FLUENT 1 May 5, 2011 11:58
Problems with Fluent Jacek Main CFD Forum 2 August 16, 2002 04:14
