How to set rotating wall as boundary condition
Old   May 25, 2009, 05:22
Default How to set rotating wall as boundary condition
Babu
babu is on a distinguished road
Hi, I am quite new in CFD simulation. I am doing a simulation something like that, there is a rectangular surface. In the surface there is a restriction like a orifice plate(actually another rectangular plate) in the middle position attached to the upper edge. The upper wall is statinary and the lower wall is rotating.the lower wall is actually a shaft. How should I define this roatation as a boundary condition in the lower wall which is rotating. Its a 2d problem. I have defined the problem as a axisymmetric model
babu is offline   Reply With Quote
Old   May 25, 2009, 06:31
tjut-wx
jeniuswx is on a distinguished road
In my opinion, you can try to use the MRF method,in the fluent help,youcan find the example refered to the MRF!
Good luck!
jeniuswx is offline   Reply With Quote
Old   May 25, 2009, 10:51
Babu
Good luck!
I have checked the example. But for my case it is only one reference rotating frame problem. I have also checked the single reference frame example.Could you tell me is it ok if i do like this " I take the rotaing edge(the line as it is 2d) as a wall and define it as a rotational wall and give the value of shaft rotation to that wall. Because there is a option in fluent to do the wall as a rotating wall. But in the example they have given the rotation speed to the fluid zone. Should I give rotation to the fluid zone or only in the inner edge?
Old   May 25, 2009, 21:01
tjut-wx
you should define a fluid zone which contains the edge you said,and then define this zone as a ratation field!
Old   May 26, 2009, 03:45
Babu
Should I make different zone for the near rotaing wall section or should I take all the fluid as rotating?
Old   May 29, 2009, 05:08
Anupam Jain
anupamjain76 is on a distinguished road
Consider entire fluid zone as rotating.
anupamjain76 is offline   Reply With Quote
Old   August 3, 2011, 12:02
soroush.armd@yahoo.com
soroush is on a distinguished road
hi
I want to model a liquid film on a rotating disk,I use axisymmetric swirl,is it correct?
I heard something about moving refrence frame!does it work for my modeling?
tnx!
soroush is offline   Reply With Quote
Old   December 14, 2013, 04:48
subhas hunasikatti
subhas.hunasikatti@gmail. is on a distinguished road
Hi friend i am ding cpu cooling system problem, in this i have to given the SNPS FAN rpm , please tell me how can i give the fan rpm in fluent....
thank you
with regards
subhas
subhas.hunasikatti@gmail. is offline   Reply With Quote
thermal boundary condition at coupled wall gokul patil FLUENT 2 June 19, 2014 05:07
Wall boundary condition – UDF Ssn FLUENT 0 January 25, 2008 03:43
Variable temperature wall boundary condition Virginie FLUENT 2 October 2, 2007 09:23
UDF hook on the WALL boundary condition Luke FLUENT 0 June 7, 2006 11:54
pressure boundary condition on the wall fluideniro Main CFD Forum 12 December 24, 2003 01:10
