-   -   How to create non-uniform velocity profile in FLUENT? (http://www.cfd-online.com/Forums/fluent/1279-how-create-non-uniform-velocity-profile-fluent.html)
pankaj September 12, 1999 12:43
hi! I am a new user of FLUENT.I will be grateful if somebody tells me how to apply & create non-uniform velocity profile as boundary conditions.
thanks.
Allan Zhao September 12, 1999 13:12
Re: How to create non-uniform velocity profile in FLUENT?
Hello, there are a few ways to create non-uniform velocity profile as boundary conditions. If you know the Graphical User Guide, you can go to create boundary panel. There are three velocity components to input (u,v,w). Below each input bar, you will see a defaut "constant" input request. You can change that to piecewise, polynomail or harmonic profiles. After you click each of these choices, next step will be straightforward to you. Good luck. Allan
Demselles Hollowajiawoak September 13, 1999 15:08
You could write a profile and read it into Fluent example from the menu pick read profile
((profile_vel_inlet 4) (x 0 0 0 0 ) (y 0 0.25 0.5 0.75 ) (x-velocity 0 0.5 0.5 0) )
Note: the 4 represents the total number of points in the profile. When you set the boundary condition and choose the correct profile, fluent interpolates the values so if your grid is unstructured your profile does not have to match the grid locations.
regards Demselles
Marco Bonizzi October 3, 1999 12:24
I'm writing to you from Italy.As FLUENT/UNS user I just can tell you that, in order to use a non-uniform velocity profile, you should do it by a FORTRAN routine. Unfortunately I cannot tell you anything else. Best luck!
glenn creten October 21, 1999 05:26
Dear Marco,
I have used non-uniform profiles for velocity and other scalars. I think the easiest way to create these profiles in Fluent is as I did:
First write out your profile at the inlet boundary You then obtain a profile file, which contains vectors of x, y, z, and (e.g.) the velocity components You can read these data in a spreadsheet, e.g. Excel, and replace the velocity components by a function of x,y,z. Then save the altered data as text file, and read this back in into Fluent as profile. Finally, you can then use these profiles as boundary conditions for the inlet.
Good luck,
Glenn.
PS. Can you transmit this to the person that posted the original question, since his mail was not on the discussion forum
ang4335495 January 4, 2010 23:43
Hello, I am new Fluent user. From this forum, I have read the case about using Excel to create the wind profile. However, there are some problems that I need help from guests inside this forum. First, I have tried to write the profile file using fluent and what shows in the excel is only X - vector. How can I get Y and Z vectors results? Another problem is that how can I write a new profile based on the excel file? By using calculation such as wind power law to calculate it? Hope one of the guest inside here can reply me soon. Thank you!
p07ip705 March 29, 2012 05:46
Non uniform velocity at inlet of domain
First you run the problem with constant velocity and then write profile for that constant velocity input. Now change the input velocity as per your requirement and re-read that profile file and solve the problem.
