Home > Forums > FLUENT
Any tutorial for heat exchanger ?
Old   December 25, 2013, 09:32
Default Any tutorial for heat exchanger ?
Ugur
Ozora is on a distinguished road
I want to simulate a simple heat exchanger model. My main purpose is the compare different materials.
Thanks for your help.
Ozora is offline   Reply With Quote
Old   December 26, 2013, 04:44
Default Heat exchanger tutorial
Санкт-Петербург
Anton Mandrik is on a distinguished road
This tutorial seems fine
http://www.youtube.com/watch?v=oInrZqVmDVY
However I am thinking now how to make an assembly with saving of inner surffaces. There is a fluid volume in this tutorial that is hidden in the pipe. Author of tutorial says to save the assembly as part (SLDPRT). After such save Solid saves only outter surfaces and two circles left from a fluid volume.
If anybpdy knows how to save assembly as a part saving all the inner surfaces..Good man! I will appreciate very much your help!
Another tutorial is here, but unfortunately only for russians((
http://www.youtube.com/watch?v=EK994Vfg4u0
Anton Mandrik is offline   Reply With Quote
Old   December 26, 2013, 04:53
Санкт-Петербург
I tried parasolid instead of SLDPRT and Got some problems with named selections.. Ansys said "model information is incompatible with incoming mesh" and said that there are no surfaces for one of my named selection..however it was.
Old   December 27, 2013, 04:45
Ugur
Cant we just use "dont merge" option ? Why we should assemble parts ? Is it because of the faces ?
Thank you,
Old   December 27, 2013, 05:05
Санкт-Петербург
don't merge option in Solidworks?)
I didn't see that.
I am just talking about the tutorial and that some actions fail in practice.. (which is strange)
Old   December 27, 2013, 05:16
Ugur
Yes, while you create "inner pipe" you can see an option as dont merge. I use it so offen. I will try to do same tutorial so i can give you an answer later
Old   December 27, 2013, 05:18
Санкт-Петербург
Hm-m..cool
I'll try it in Solidworks in the evening.
And by the way there was something strange with fluid region..It had two surfaces betweeen the circles (two walls of the pipe) I am not a professional user.. so I don't know what is a problem.
Thread Tools
Trackbacks are On
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 16:01
Heat Exchanger Simulation tightaznbreaka FLUENT 0 March 18, 2010 16:45
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 10:41
