Home > Forums > FLUENT
problems compiling udf
Old   January 1, 2014, 12:31
Exclamation problems compiling udf
Spartacus1 is on a distinguished road
Hello everyone I am new in this forum and I hope you can help me with my problem.
I'm trying to crare a motion of sloshing, with Fluent, in a rectangular tank through dynamic mesh.
I have a problem of compilation of the UDF, in particular the library is not created and load by fluent showing the following error:
Deleted old libudf \ ntx86 \ 2ddp \ libudf.dll
******** 1 file copied.
(system "copy C: \ Fluent.Inc \ fluent6.3.26 \ src \ makefile_nt.udf libudf \ ntx86 \ 2ddp \ makefile")
(chdir "libudf") ()
(chdir "ntx86 \ 2ddp") ()
velocitax.c
# Udf_names.c Because Of Generating makefile velocitax.obj
Done.
"c :/ users / manna / desktop / exercises with vx"
Opening library "libudf" ...
Error: open_udf_library: Could not find the file specified.
Error Object: ()
can someone help me??
thanks
Spartacus1 is offline   Reply With Quote
Old   January 3, 2014, 06:46
I need a solution.
My project can not move forward if you do not solve the problem
Old   January 3, 2014, 09:17
pakk will become famous soon enough
It could be because you have spaces in your folder name.
Try changing them to underscores (exercises_with_vx), it might help.
pakk is offline   Reply With Quote
Old   January 3, 2014, 09:45
hello Pakk
I tried to change the name of the folder, but I have not solved.
the problem that appears in the log file is as follows:
Microsoft (R) 32-bit C / C + + Optimizing Compiler version 16.00.30319.01 for 80x86
Copyright (C) Microsoft Corporation. All rights reserved.
"sed" not recognized as an internal or external command,
* operable program or batch file.
NMAKE: U1077: 'sed': return code '0 x1 '
Stop.
can you help me?
If you really want I can send you the code c that I have written
Old   January 3, 2014, 10:37
I don't think your udf is giving the problems, that would give different kinds of error messages. You are probably not able to compile any udf at all (am I right?)
It may have to do with your systems settings, or with the way you are trying to compile them. Are you starting Fluent from the SDK command prompt? I am no expert on these things: it works on my computer, but I didn't install it.
Old   January 3, 2014, 11:15
Dear Pakk
I created a folder on the desktop where I put mesh files and code c. than
i start fluent 6.3.26 from the command prompt Visual Studio 2010 and I adopt the compilation process of the interface Fluent:
Define> user defined> function> compiled> add surce> build library> load
this is my procedure ..
Something wrong in your opinion?
if it is something that concerns the settings of the system you can tell me what i have to make
thanks for your answers
Old   January 4, 2014, 22:31
CAO Liushuai
shuai_manlou is on a distinguished road
UDF
shuai_manlou is offline   Reply With Quote
Old   January 5, 2014, 05:54
thanks I solved the problem of compilation ,
it concerned the setting of environmental variables , I can now load the librer .
I still remain two problems :
1 . fluent shows some worning :
c: \ fluent.inc \ fluent6.3.26 \ src \ machine.h (114) : warning C4005 : ' stdout ' : macro redefinition
********C: \ Program Files \ Microsoft Visual Studio 10.0 \ VC \ INCLUDE \ stdio.h (158) : see previous definition of ' stdout '
c: \ fluent.inc \ fluent6.3.26 \ src \ machine.h (115) : warning C4005 : ' stderr ' : macro redefinition
********C: \ Program Files \ Microsoft Visual Studio 10.0 \ VC \ INCLUDE \ stdio.h (159) : see previous definition of ' stderr '
c: \ fluent.inc \ fluent6.3.26 \ src \ machine.h (116) : warning C4005 : ' stdin ' : macro redefinition
********C: \ Program Files \ Microsoft Visual Studio 10.0 \ VC \ INCLUDE \ stdio.h (157) : see previous definition of ' stdin '
# Linking libudf.dll Because Of makefile user_nt.udf udf_names.obj velocitax.obj
Microsoft (R) Incremental Linker Version 10.00.30319.01
Copyright (C ) Microsoft Corporation. All rights reserved.
***Creating the library and object libudf.lib libudf.exp in progress ...
Done .
"c :/ users / manna / desktop / exercises "
Opening library " libudf " ...
Library " libudf \ ntx86 \ 2ddp \ libudf.dll " opened
velocitax
Done .
I can neglect them ? ?
2 . I have to simulate a motion of sloshing in a rectangular tank in particular I have to give the fluid a rate of oscillation of the type :
vx = A * f * sin ( f * t)
I have created a UDF ufilizzando the following function:
DEFINE_CG_MOTION
so as to assign the speed vx to the center of gravity.
then hooking this function by activating dynamic mesh and applying in zone> rigid body> udf motion.
my question is the following:
is it right to use dynamic mesh to create an oscillatory motion of the fluid?
there are other methods to assign the vx fluid?
Old   January 5, 2014, 10:48
CAO Liushuai
Maybe you can type your code here, maybe i can give you some help.
Thread Tools
Trackbacks are On
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 7 January 2, 2013 11:49
Errors when Compiling UDF: error C2040/error C2099 Julian K. FLUENT 1 December 21, 2008 01:23
UDF problems 2 Paolo Lampitella FLUENT 2 September 7, 2005 19:05
Compiling UDF on SUSE 8.0 L-P FLUENT 0 September 23, 2003 07:43
DEFINE_GEOM UDF Problems Pat FLUENT 0 August 14, 2003 13:16
