Ansys Fluent mixing help
Old   January 10, 2014, 09:32
Default Ansys Fluent mixing help
Erinn Sapsford
esapsford is on a distinguished road
I am having some trouble setting up a scenario and was hoping someone could help.
Basically the scenario is a pool of water with various obstructions within the pool, the pool has an inlet and outlet, and i am wanting to inject another chemical into the water and look at the movement of the chemical.
I am not sure which models to be using, whether its a multi-phase or if i can use the energy model with K-epsilon and then turn on species transport.
Another problem im getting is that if im using the inlet as the injection location for the water and chemical, how do i specify that two different materials are being injected from the inlet?
Hope this makes sense, if not let me know and i will try to clarify.
esapsford is offline   Reply With Quote
dispersion, fluent, mixing, species mixing
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
prePDF preprocessor in FLUENT (ANSYS 12 version) anee Fluent UDF and Scheme Programming 7 March 18, 2013 22:57
Fluent v6.3.26 better than Ansys v12.1 jemyungcha FLUENT 2 August 24, 2012 23:10
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation Volker P. ANSYS Meshing & Geometry 22 January 17, 2012 17:27
how to modeling heat by fluent and ansys? njiit FLUENT 0 December 9, 2009 00:39
