Porous_jump in fluent
Old   February 28, 2014, 03:23
Default Porous_jump in fluent
Erlanda Pane
Erlanda is on a distinguished road
Excuse me,
Hello everybody, I have one question.
Why I can't find porous_jump in fluent boundary conditions ?
Thank you for your help.
Erlanda is offline   Reply With Quote
Old   February 28, 2014, 04:27
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hello Erlanda,
it means that for this boundary you can't select this boundary condition.
Can you post some pictures of your system?
Regards
Bionico
Bionico is offline   Reply With Quote
Old   February 28, 2014, 09:38
Erlanda Pane
Hi Bionico, thank's for your help.
This is my picture when Iam running it with ansys fluent.
Old   February 28, 2014, 12:24
Andrew Kokemoor
Kokemoor is on a distinguished road
Are you selecting an internal face? Porous jump is an internal boundary condition, so it can't be used for external faces where inlet/outlet conditions can be applied.
Kokemoor is offline   Reply With Quote
Old   February 28, 2014, 21:49
Erlanda Pane
Yes Iam selecting an internal face when I build geometry in meshing process, but When Iam processing in fluent boundary condition, I can't find porous jump in optional.
So, what I must to do ?
Old   March 3, 2014, 05:03
Bionico's Avatar
Flavio
Hi Erlanda,
I can open your mesh: which boundary condition do you want to define as porous-jump?
regards
Bionico
Old   March 3, 2014, 06:23
Erlanda Pane
Hi, Bionico
The porous_jump in the bottom side of second volume (inlet volume).
Thank you
Old   March 4, 2014, 02:29
Bionico's Avatar
Flavio
Hello Erlanda,
inlet boundary condition can't be defined as porous-jump: it isn't an interior face. About your mesh, I have a doubt when I display it: are the two volumes overlapping?
Regards
Bionico
Old   March 4, 2014, 04:12
Erlanda Pane
Hi Bionico.
No, the two volume aren't overlapping.
The second volume inside of the first volume.
After that, I have one question. In above side of second volume, I definied boundary condition was outflow, and I had some problem with outflow and pressure outlet (boundary condition in above side of first volume). Why were the both of them domain, and didn't definition ?
Old   March 4, 2014, 06:14
Bionico's Avatar
Flavio
Hi Erlanda,
What you used as mesher? I think you made some mistakes in meshing because I see two disconnected volumes (as I said before I see the interior mesh of the bigger volume overlapping the smaller one), so inlet isn't an interior face: I suggest using a conformal mesh.
Maybe also the problem with outlet boundary is the same.
Regards
Bionico
Old   March 4, 2014, 07:32
Erlanda Pane
Hi Bionico.
How can I find conformal mesh menu ?
Thank you.
Old   March 4, 2014, 07:41
Bionico's Avatar
Flavio
I usually use DesignModeler + Meshing as pre-processing softwares: in order to obtain a conformal mesh you have to put all the bodies in the same Part. If you create different part, you'll obtain a non-conformal mesh.
If it's not a problem, post your geometry (in Parasolid or Step format).
Regards
Bionico
Old   March 4, 2014, 07:54
Erlanda Pane
Hi Bionico.
Anyway I use Gambit software for pre-processing.
Is it possible to find conformal mesh in Gambit ?
Thank you.
Old   March 4, 2014, 08:40
Bionico's Avatar
Flavio
I used Gambit in the past, but I don't remember how to create conformal mesh, unfortunately
Check on the Manuals.
Regards
Bionico
Old   March 5, 2014, 04:06
Erlanda Pane
Oh, okay.
Thank you Bionico.
I will try it.
Connecting Fluent benefits and Injection Molding Software Jim87 FLUENT 1 August 6, 2023 16:06
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
