How to rectify the error of mesh check failed
Old   November 17, 2011, 04:34
Default How to rectify the error of mesh check failed
mahendra
mrdumpa is on a distinguished road
Hi friends,
This is mahendra. I imported the mesh from icemcfd(tet) to fluent. While doing the mesh check operation i got the problem. ie
WARNING: 3 degenerate contact points identified.
To print out a list of the contact points call (print-contact-points).........................
Done.
WARNING: Mesh check failed.
Can anyone help me to solve this problem
Thanks in advance
Mahendra
mrdumpa is offline   Reply With Quote
Old   November 17, 2011, 15:35
raj
raj.cfd is on a distinguished road
In ICEM as far as i remember, you have mesh check options that looks for t-connections, degenerate cells, free edges etc etc. try running them first. Look for mesh quality, especially the skewness, AR, OQ, EQ etc . if the mesh is good enough fluent doenot complain about mesh check failed.
In fluent you do have mesh repair options, use them using text commands. It should solve your problem.
Please let me know if this is useful....
raj.cfd is offline   Reply With Quote
Old   January 24, 2013, 02:34
Post
davia
Striving is on a distinguished road
i try it ,but it didn't have this effect. That problem always is not sloved.
Striving is offline   Reply With Quote
Old   May 18, 2013, 23:43
Talking
davia
Originally Posted by mrdumpa View Post
Hi friends,
Done.
Thanks in advance
Mahendra
are you fix the problem? I would like to know the solution。
thank you
Old   January 22, 2014, 12:11
Default run with no issues
MDB
Manuel Díaz Brito
MDB is on a distinguished road
And a year later... my contribution: getting the same mesh check failure "1 degenerated point" the simulation runs with no further complaints! However it would be better to don't have such errors in the mesh for improved convergence etc...
MDB is offline   Reply With Quote
mesh check failed / degenerated contact points shohin FLUENT 16 April 11, 2014 23:32
Mesh Check Failed, Please Help! fyp ANSYS 4 August 29, 2010 06:41
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Storage alloction failed in cfx mesh Mario Tremblay CFX 2 March 6, 2009 11:35
user defined function cfduser CFX 0 April 29, 2006 11:58
