January 23, 2014, 07:18 |
3D initialization from 2D solution
federico
Rep Power: 13 |
Hi all,
Is it possible in Ansys Fluent 14.5 to modify the interpolation file obtained from a 2D solution in such a way that is read from a 3D solver? In the web I found this thread http://www.cfd-online.com/Forums/flu...d-results.html But I can't find a way to enter and modify the 2D.ip file that I generate (I have an ubuntu OS and apparently no program can read the extension of the ip file) Thaks for helping Federico |
January 23, 2014, 07:56 |
Alex
Rep Power: 46 |
It is only a text file, so any text editor should be able to handle it.
January 23, 2014, 08:25 |
federico
Rep Power: 13 |
I thought so, but I actually tried to open it with different programs and either it doesn't work or it doesn't show most of the things with comprehensible font
I tried with: gedit, vi, vim, gnome-open, cream... It doesn't work What do you use? |
January 23, 2014, 09:13 |
Alex
Rep Power: 46 |
Ah i see...
By default, the option "Binary file" is active when you write an interpolation file. See the check box at the lower left corner of the interpolation dialog. Deactivate it while writing the interpolation file and you will get an ascii file. |
January 24, 2014, 04:37 |
federico
Rep Power: 13 |
YES, that was the problem!!
Thanks |
May 5, 2017, 18:21 |
Bharatvaaj
Rep Power: 9 |
Hey Alex (Flotus),
I have reduced a 3D domain into a 2D (planar) domain. The inlet for 3D is a face(surface) at the circular pipe inlet. For the 2D it is an edge. Is my mass flow inlet same in these cases? or only the mass flux remains the same? How do I convert mass flow rate inlet initialization between 3D and 2D planar domains? |
UDF - Error while Solution Initialization | QuocHung_Phan | Fluent UDF and Scheme Programming | 2 | October 11, 2013 03:03 |
Why 3D solid-pore geometry showing diverged solution? | Sargam05 | OpenFOAM | 0 | December 3, 2012 15:45 |
Using fmg initialization with solution steering from journal | Costoich | FLUENT | 0 | April 20, 2011 14:19 |
Conduct initialization with a old mesh solution | Jianfeng Zou | FLUENT | 1 | September 12, 2007 06:06 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
