January 24, 2014, 12:05 |
UDF of a soil tube
amel
Rep Power: 15 |
Hello
I would like to model a thermal storage tank constructed of side by side tubes placed at the surface of the soil. the fluid entering the tubes is Hot water. the fluid outside the tubes is air. I have constructed 2D geometry with Gambit (see figure). I would like how I can model the inlet and outlet of every tube in FLUENT. Because the water enters at a certain temperature to heat the air and then quits tubes. |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
Tube inside a tube simulation | Rashmichem | Main CFD Forum | 0 | December 14, 2010 01:52 |
Help Parallelizing UDF | AndresC | FLUENT | 0 | February 25, 2010 15:50 |
DEFINE_ON_DEMAND UDF: How to declare A[ND_ND], etc | jx | FLUENT | 1 | November 6, 2003 17:23 |
DEFINE_GEOM UDF Problems | Pat | FLUENT | 0 | August 14, 2003 13:16 |
