January 27, 2014, 07:11 |
DES Length Scale,grid spacing,delta max
Ali.E
Rep Power: 15 |
Hello all,
I want to compute delta x (distance between two cell points) in a 3D simulation. Actually, I want to caclucate DES Length Scale and maximum grid spacing is a important parameter to calculate. Actually, 3 grid spacing is needet to calculate in 3D problem and the maximum of them is used in DES Length Scale calculation. My problem is how can I find the grid spacing for each cells. Please help me |
February 5, 2014, 14:29 |
Ali.E
Rep Power: 15 |
I think that the best way is writting a udf which computes the length scale.
the length scal equation is: L_s=sqrt(k)/(Bs*delta_max*C_des*w) Bs=0.09 , C_des=0.61 k=turbulent kinitic energy w=specific dissipation rate delta_max=max(delta_x,delta_y,delta_z) may I ask you which macros should be used? |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
