January 27, 2014, 07:34 |
side by side heat exchanger
amel
Rep Power: 15 |
Hello
I have to model a side by side heat exchanger. The inner fluid is geothermal water (inlet temperature= 70°C and outlet temperature=40°C). the outer fluid is cold air circulating inside a circular collector. The heat exchanger is constructed of side by side pipes (diameter = 20 cm) placed at the surface of the soil. I have constructed a 2D geometry but the problem is how to mention to Fluent that the water enters every pipe and quits the other side after increasing the temperature of the air. What type of inlet boundary I have to chose to These pipes? Did I have to calculate the flow rate for enery pipe and put it as boundary? Did I have to write a program please help me? |
Heat Exchanger Model | sak2129 | FLUENT | 3 | September 26, 2017 01:29 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Pressure drop in a heat exchanger | Diana | FLUENT | 5 | December 13, 2007 09:33 |
heat exchanger in typical air-conditioning system! | Yang Bin | Main CFD Forum | 0 | May 11, 2005 08:16 |
