need help! for vane rotary compressor cfd
Old   November 6, 2012, 04:11
Default need help! for vane rotary compressor cfd
adib
arebung is on a distinguished road
hello..i want to simulate suction process for rotary vane compressor..it is possible to use ansys fluent..and can you guide me in doing that..im a student..this is for my master project..t.q
arebung is offline   Reply With Quote
Old   November 7, 2012, 15:05
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
Yes it is. You can simulate the flow involved rotor & stator interaction with Multiple Reference Frame approach (MRF).
vicarious is offline   Reply With Quote
Old   November 8, 2012, 02:04
cfd seeker is on a distinguished road
For advise on my part, I think you need to change your project because it is tough ask for masters scope because
1. there is a translational motion of vanes in and out of vane cavity, to incorporate it you need to write a Udf
2. For Rotational motion of the rotor, you need to write another Udf
3. you need to adjust them in such a way that during rotational motion the vanes translational motion follow the cavities
4. I haven't found any good reference related to this work in literature, i always believe one should first do the literature review and make sure that he has enough references and data.
cfd seeker is offline   Reply With Quote
Old   November 8, 2012, 09:35
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
CFX has better options for this. See this
http://www.edr.no/blogg/ansys_blogge...mmersed_solids
https://www.sharcnet.ca/Software/Flu...solidsmod.html
Far is offline   Reply With Quote
Old   November 8, 2012, 09:54
vicarious's Avatar
Pedram Mojtabavi
I'm wandering why does one need to write UDF for rotor motion. Because I've already simulated a stage of a test axial compressor using sliding mesh method. It just needed a rotor cascade attached to the stator cascade and got linked from top and bottom. Giving a velocity to the rotor and it moves relative to the stator cascade.
Old   November 10, 2012, 01:34
imran9697 is on a distinguished road
Axial compressor is different from rotary vane compressor, it can be done with simple sliding mesh technique. you can check rotary vane compressor working on internet and you will agree with what CFD seeker has posted. You can model it using immersed solid approach posted by far, but i am unsure about its experimental validation because it can not account for in and out motion of vanes in the cavity.
imran9697 is offline   Reply With Quote
Old   November 10, 2012, 05:20
vicarious's Avatar
Pedram Mojtabavi
Thanks for the heads up.
Old   November 19, 2012, 22:28
adib
thanks for the link..if i want to simulate the suction port and discharge port of the compressor how im going to validate this?
Old   January 24, 2013, 12:11
Exclamation
Pramod
pramod is on a distinguished road
What about flownex? Can it be done using flownex?
pramod is offline   Reply With Quote
Old   February 25, 2014, 00:26
davia
Striving is on a distinguished road
do you have flownex? i need it ,i think i can communicate with you
Striving is offline   Reply With Quote
rotary atomizer eng_norouzi CFX 12 August 14, 2012 19:14
help how to simulate the velocity in the rotary atomizer xjm659 CFX 7 October 24, 2011 05:28
Rotary Engine Combustion Simulation With SolidWorks Flow Simulator 2009 saaguy FloEFD, FloWorks & FloTHERM 9 December 7, 2010 20:55
Rotary drum attached with baffles nutow CFX 11 November 12, 2010 14:36
2d rotary vane pump problem R.SRIHARI Main CFD Forum 2 February 2, 2009 00:28
