Stirred tank convergence issue
Old   January 16, 2014, 23:26
Default Stirred tank convergence issue
Gurpreet
gurpreet89 is on a distinguished road
hi friends
i am simulating a stirred tank using mrf in ansys 14.0 . i am using SIMPLE presure -velocity and first order discretization scheme, once it partially converge then i switch to QUICK..I am able to converge to 10^-3 but i want it to converge till 10^-4. the problem is that all the errors in residuals goes to 10^-4 exept for 'epsilon'.what should i do.plz help
gurpreet89 is offline   Reply With Quote
Old   January 17, 2014, 04:46
Gurpreet
the convergence graph is something like this
can i say that i converged it to 10^-4 .i did around 9000 iterations
Old   March 4, 2014, 14:50
Eakarach is on a distinguished road
Try to reduce the relaxation factor for turbulent quantities. I hope it can be help you.
Regards
Eakarach
Eakarach is offline   Reply With Quote
Old   March 5, 2014, 05:20
ghost82's Avatar
Rick
ghost82 will become famous soon enough
it seems converged to me; try to create some monitor surfaces and monitor some variables such as velocity for example; if that variable doesn't change solution is converged.
Daniele
ghost82 is offline   Reply With Quote
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 19:55
continuity convergence problems in stirred tank nycera FLUENT 5 February 20, 2011 19:19
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
CFX-Solver, issue with convergence behavior Andy CFX 7 September 5, 2006 03:24
Stirred Tank Geometry in Ansys gopalkasat CFX 6 December 22, 2004 13:32
