Home > Forums > FLUENT
Monitor Total Heat Flux
Old   February 28, 2014, 09:11
Question Monitor Total Heat Flux
Tom Marquardt
TomM is on a distinguished road
Hey guys,
I have a question. I'm trying to monitor the total heat flux through a steel wall over time. I have a laminar water stream passing by and trasfering the heat to the nearby wall.
I know that I can check the Flux under Reports/Fluxes/Total heat transfer rate/... at any point, but is it possible to monitor this over time?
I tried using Monitors/Integral/Wall Fluxes/Total surface heat flux, but this stays zero over time without any change?
Any ideas?
TomM is offline   Reply With Quote
Old   April 8, 2016, 04:52
Default same problem, did you solve it?
Makal is on a distinguished road
Makal is offline   Reply With Quote
Old   April 8, 2016, 05:03
Tom Marquardt
Hey Makal,
indeed I did but three years ago and I don't have access to the files or the software anymore. But I think I had to use a different approach and monitored the enthalpie flux h through the wall. I also checked the flux into the inlet and out of the outlet in order to have a tool of validation (Inlet flux minus Outlet flux = Wall flux). Hope this is helping. Feel free to contact me via private message.
Greetings
Tom
Old   April 12, 2016, 07:40
it seemed a bit complicted so i asked support. They said it was no way to monitor the total heat transfer out but you can write it to a text file. I'm logging everything in a textfile already so at the end of my simulation i added
/report/fluxes/heat-transfer no Outlet () yes outlet.flp
this calculates the total heat transfer at the Outlet and writes it to a file called outlet.flp. I could end it with no and I will only get it in my log file. Its good enough for me
Thanks though
Thread Tools
Trackbacks are On
Wall Heat Flux & Temperature Greg Perkins FLUENT 10 November 20, 2015 10:32
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
Negative Heat Flux shashank312 FLUENT 3 December 9, 2011 18:00
CFX - wall heat flux divarano CFX 2 December 4, 2006 17:14
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 0 August 22, 2005 10:34
