Deforming Mesh Issue
Old   March 10, 2014, 11:19
Default Deforming Mesh Issue
Robert Gonçalves
brightfame3 is on a distinguished road
Good afternoon.
I am simulating an IC Engine in fluent and I am having some issues with my results and i believe it is due to a problem with the deforming mesh. The issue in question is shown in the image. My problem is 3D, however I have posted the faces which are problematic in order to visualize easier. As you can see, there are two cells in particuar that keep on stretching and become very large and influence the rest of the surrounding cells. I have tried modifying the parameters of all deforming zones, but I have had no success. Any suggestions?
Thanks for your time! Greetings!
brightfame3 is offline   Reply With Quote
Old   March 13, 2014, 08:41
Paritosh Vasava
vasava will become famous soon enough
This could be because your moving boundary and stationary boundary are sharing those elements. If I am not wrong you may need some additional condition for that stationary face also. May be a fixed position. Also try with refined mesh so that there are no elements shared between moving and stationary walls.
vasava is offline   Reply With Quote
Old   March 13, 2014, 09:25
Default Dynamic Mesh
Robert Gonçalves
Thanks for your reply! I was suspecting that the problem could be that. The white faced mesh is the deforming face which "grows" with the valve movement. The yellow faced mesh is a symmetry face which also deforms due to the valve movement. The other face that shares the same elements is a wall and I haven't defined anything to it. So, just to be sure, you are saying that I should define that wall as stationary? I was trying to avoid refining the mesh, since I will get a very large number of elements due to the size of my domain.
Greetings! And thanks once again!
Old   March 14, 2014, 02:02
Paritosh Vasava
By stationary I mean you fix its position of that wall. You could do this by use of DEFINE_GEOM macro. See following example where X-coordinate for a wall is fixed to 0.1.
DEFINE_GEOM(plane, domain, dt, position)
	position[1] = 0.1;
I have seen this in 'Oscillating Membrane' tutorial.
Old   March 15, 2014, 11:57
Default Thank you for the advice
Robert Gonçalves
Thank you for the advice! I will give it a try and I will give a feedback if it did or not work. Thanks once again!
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Liquid Volume Error when VOF + Deforming Mesh Used NCle CFX 8 June 8, 2012 13:07
Moving Mesh Velocity Issue: Mesh velocity does not equal displacement Doginal CFX 2 September 8, 2011 12:02
