Home > Forums > FLUENT
fluent convergence problem
Like Tree2Likes
  • 1 Post By zombiaska
  • 1 Post By ghost82
Old   March 12, 2014, 13:59
Question fluent convergence problem
itzme is on a distinguished road
hi guys,
I am having difficulty with convergence,especially continuity residuals.
My model and boundary conditions are shown below.Air flows in a swirling pattern and creates negative pressure in the central region.
the nozzle is 1.5 mm and the gap between skirt and work-piece is 0.3 mm.
I want to find the pressure distribution on the work-piece..
The peak velocity is around 100 m/s only and so pressure based solver is sufficient...right?
The mesh created has a max skewness of .7 with average skewness of .2
Is the mesh too coarse.do i have to increase the no. of elements where thickness is very less.( I am modelling the fluid domain only and considered an outer envelope to apply pressure boundary condition)
How to attain faster convergence for this case.
should I use simplec or coupled ??
do i need to modify the under-relaxation factors ?
also,how to reduce back-flow ?
Any help is appreciated...
thanks in advance...
itzme is offline   Reply With Quote
Old   March 13, 2014, 03:24
Simas
zombiaska is on a distinguished road
Yes you can do this higher under-relaxation factors will accelerate. If iterations grahps go up it means you have too high relaxation factors and need to lower it.
itzme likes this.
zombiaska is offline   Reply With Quote
Old   March 13, 2014, 08:31
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
itzme,
1) What turbulence model do you use?
2) Can you show the residuals?
3) Numerics ("Solution Methods") are?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   March 13, 2014, 08:46
Originally Posted by RodriguezFatz View Post
itzme,
Thanks for the reply
K-e RNG model
I dont currently have the residuals picture...everything except continuity converges...
Simplec... Initially with first order and then to second order...
Old   March 13, 2014, 10:34
Philipp
Di you try to run the whole case with much lower massflow? Try e-5 inlet massflow instead of e-4, and tell us what happens.
Old   March 13, 2014, 10:51
Well...I managed to achieve convergence... but the pressure distribution on the plate is not accurate...
Will improving mesh or increasing no. of elements yield correct results??
Thanks in advance
Old   March 13, 2014, 10:52
Philipp
You mean convergence for the e-5 case?
Can you post a picture of the y+ value on your surfaces?
Old   March 13, 2014, 11:15
No...for the e-4 case itself...and I am not using any type of inflation in the mesh....is y+ value significant for accuracy and convergence of solution....
(sorry, I am only a beginner in cfd analysis)
Thanks
Old   March 13, 2014, 11:18
Philipp
y+ is the normalized size of your cells, perpendicular to the surface, so its always plotted on the surface of your domain. If it is too large, the boundary conditions of the turbulence model become garbage.
What did you change to achieve convergence?
To your question: Of course results can get better if you make the grid even smaller. But you already have 1.3 mio cells for such a simple geometry. Do you have ICEM for meshing or just the ansys meshing?
Old   March 13, 2014, 11:32
Thanks for the info
I refined mesh a bit and changed the relaxation parameters.
I am not familiar with icem meshing.
Old   March 14, 2014, 07:11
Philipp
You should have a look at the y+ anyway. Maybe post the pictures!
Old   March 16, 2014, 00:23
Is it possible to do a 2-D analysis for this case ???
Old   March 16, 2014, 06:49
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
you mean axissymmetric; anyway no, because there is a tangential nozzle.
itzme likes this.
ghost82 is offline   Reply With Quote
Old   March 17, 2014, 10:11
Default weird CP distribution near trailing edge for NACA0012
  #14
shubham jain
shubham jain is on a distinguished road
i am simulating naca0012 with Gurney flap
mesh using ICEM CFD
simulation using FLUENT, k-e RNG, Re=3e06
I have a problem in CLEAN Airfoil (without any gurney flap) in its Static pressure distribution (CP).
1. CP values of pressure and suction surface intersect each other near the trailing edge for every angle of attack.
2. Also there are many riggles (wavy nature of CP) in the CP distribution
Though the pathlines seem to be fine
can anybody explain this weird CP distribution and how can i rectify it???
thanks in advance
shubham jain is offline   Reply With Quote
Thread Tools
Trackbacks are On
Convergence Centurion2011 FLUENT 27 February 7, 2016 12:58
serial/parallel problem in force saving convergence history behest FLUENT 11 July 22, 2014 03:49
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
Fluent - license problem. Marcin FLUENT 1 March 4, 2005 12:41
convergence problem limseokmin FLUENT 3 November 14, 2004 13:43
