Defining properties to a fluid that is not in fluent data base
I am currently working on analysis of a mini channel heat exchanger which is using oil as the cooling medium (flowing inside the channel). How do we give the properties of the specific oil as it is not in the fluent data base .. ?
if you know the properties of your customized fluid, input those values in the properties of oil and give change create.
than you for the reply :)
