Is the solution converged or not??
Old   March 19, 2014, 12:06
Default Is the solution converged or not??
yahmed is on a distinguished road
I am doing flow field simulation inside an open channel reactor, using SST model. Steady state.
continuity solution residuals don't go less than 10e-4, and all the other residual remained almost the same with a little oscillation in the values..
So is my solution converged or not?
I monitored a velocity for a point in the reactor and it was constant during the last iterations..
I appreciate any help!!
yahmed is offline   Reply With Quote
Old   March 19, 2014, 16:27
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Yes, solution is converged.
ghost82 is offline   Reply With Quote
solution is converged but a problem flow_CH FLUENT 9 June 2, 2020 09:34
simple solution converged in 9 iterations? Gabbee90 OpenFOAM Running, Solving & CFD 4 January 29, 2019 21:04
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 12:44
solution is not getting converged Nijanthan FLUENT 5 July 25, 2013 01:42
Does FOAM converge to exact solution in Laplace equation? santiagomarquezd OpenFOAM Running, Solving & CFD 0 March 26, 2010 07:52
