abhijithmohan |
March 22, 2014 03:29 |
Conjugate heat transfer in a counter flow heat exchanger
1 Attachment(s)
I am having a problem with my counterflow heat exchanger analysis in ansys fluent(conjugate heat transfer). After designing in the ansys design modeler and meshing it, and while setup was made it was found that heat transfer is not taking place between the fluid-solid interface. Later on I found that the Wall shadow was not generated at the interface.how to generate the wall shadow in this case.Thanks in advance ..:):):):)
