Applying heat flux at mesh/wall interface for a solid-fluid heat transfer?
Like Tree1Likes
  • 1 Post By sridhar.d009
Old   September 21, 2013, 01:00
Post Applying heat flux at mesh/wall interface for a solid-fluid heat transfer?
Nitin
nit4tin is on a distinguished road
I have made the model such that the fluid is flowing b/w two solid slabs as shown:-
______________________
solid 1(glass)
------------------------- <--mesh interface
fluid
-------------------------- <--mesh interface(with heat flux)
solid 2(insulator)
_______________________
\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ <--insulated boundary
I made the model in solid edge and exported geometry into meshing software.I named the interface walls as
WALL-SOLID-1,
WALL-SOLID-2,
WALL-FLUID-TOP,
WALL-FLUID-BOTTOM
and meshed the geometry using default options.then i exported *.msh file into FLUENT and used mesh interface option FLUENT to couple the walls, but to do so I had to convert these walls to interface. Now I have to apply heat flux at interface b/w WALL-SOLID-2. and WALL-FLUID-BOTTOM.Could someone please help me, how to apply this heat flux?
Any help is appreciated
nit4tin is offline   Reply With Quote
Old   September 21, 2013, 06:34
sridhar
sridhar.d009 is on a distinguished road
solid 1(glass)
fluid
solid 2(insulator)
WALL-SOLID-1,
WALL-SOLID-2,
WALL-FLUID-TOP,
WALL-FLUID-BOTTOM
physically those two are not Interfaces, those two are walls, if you give wall boundary condition fluent automatically generate wall shadow, At wall boundary you can give heat flux in thermal tab.
like.no.other likes this.
sridhar.d009 is offline   Reply With Quote
Old   September 23, 2013, 01:14
Nitin
i have already tried it, but some reason Fluent is not generating wall shadow
Old   September 23, 2013, 13:56
sridhar
may I know the names of fluid zones. or attach here your mesh file.
Old   September 28, 2013, 04:55
Nitin
hi, I solved the problem by converting the heat flux into equivalent heat generation and then providing this heat generation at the interface
Old   September 28, 2013, 08:57
François Grégoire
macfly is on a distinguished road
that's a weird way to work it out
read this mesh in Fluent, it has coupled walls and you can apply a thermal boundary condition on those internal walls (wall:002 and wall:003)
macfly is offline   Reply With Quote
Old   August 19, 2018, 14:50
Default ???
emzifer
emzifer is on a distinguished road
how do this work please explain it?
emzifer is offline   Reply With Quote
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 06:29
Heat transfer between solid and fluid Suyash26 ANSYS 4 April 22, 2013 15:59
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
